Need help finding valve spring seats for my comp 986-16 springs
Old Feb 10, 2014 | 06:14 PM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
I was looking for valve spring seats for my comp 986-16 valve springs I have aluminum heads and I asked summits tech and he said I don't have to run any don't most people usually use them?
Old Feb 10, 2014 | 07:55 PM
Re: Need help finding valve spring seats for my comp 986-16 springs
Shims usually will do the trick, if your pockets are the right size. (1.44" ±)
Bottom line is, depends on what heads you've got, and how they're set up now.
If it ends up you need that kind of thing, you might be able to use 4704 cups, or 4694 locators.
Old Feb 10, 2014 | 08:04 PM
Damon's Avatar
Keep looking. You don't want to run valve springs directly against the bare metal spring pockets of a set of aluminum heads.
Agreed with above, you don't need spring cups per se, but you need SOMETHING for the spring to work against that isn't bare aluminum.
Old Feb 10, 2014 | 11:20 PM
Engine: forged 350
Yeah that's what I thought thanks guys.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
