Replaced Ignition Coil, Now Car Won't Rev Past 3k RPM, Stutters Slightly
Old Feb 12, 2014 | 09:43 PM
92g92's Avatar
Car: 1992 Camaro Z28
My car was running more or less fine, besides a shuddering and drop in RPM at idle when in drive. The car would shudder and drop to under 500 rpm, sometimes actually dying on me. When it wouldn't die, it would shoot up to over 1k rpm and then drop back to 650 rpm studdering and shuddering. The tach also jumps and dances all the time like I had a bad wire or a short somewhere. I tried replacing the TPS to fix the idle and dying issues, that did nothing. I read of someone else fixing their tach dancing problem with a new ignition coil so I tried that, thought just maybe it would fix idle issues too. It didn't help anything, just made things worse. Now the car shudders when driving and seems to stutter a bit. When I get on it, power seems to be down and it hits 3k rpm like a wall and just stays there, maybe creeping to 3200 rpm or so. Freaked me out so I didn't romp on it to try and force it past 3k rpm lol. ALL I DID WAS REPLACE THE IGNITION COIL, WTF HAPPENED? The gray and black wires are reconnected, and the spark plug like wire on top that connects to the distributor made a resounding *click* when it snapped on. So what's up? HELP!
Old Feb 27, 2014 | 07:06 PM
92g92's Avatar
Bump
Old Feb 27, 2014 | 08:50 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: Replaced Ignition Coil, Now Car Won't Rev Past 3k RPM, Stutters Slightly
maybe a vac leak,but also may not hurt to check the fuel pressure
Old Feb 28, 2014 | 02:07 PM
92g92's Avatar
All vacuum hoses are good. Fuel filter and ICM I just replaced, runs the same. No problems before replacing the coil. Warranty-ed the coil, the new one has shown no improvement in how the car runs. Original coil was I believe the stock coil. Replaced with duralast coil from autozone, warranty-ed it out with another duralast coil. Runs like poo.
Old Feb 28, 2014 | 04:37 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Maybe your pick-up coil is bad? Your timing might be off? It's hard to say exactly what this is. Are you getting any SES codes?
Old Feb 28, 2014 | 08:39 PM
92g92's Avatar
Mmmm I don't know why the timing would be off. It threw a code 43 one time, but I think this was more due to issue than actually causing the issue. Last night after having driven the car for about 30-45 minutes, I went home and then went back out after about 10 minutes. When I got back in, it ran like a CHAMP. Flawlessly. It was 39 degrees outside and the car was warm. This morning, it ran much better but hesitated and misfired constantly at WOT. More of an occasional shudder when just cruising. I guess it could be a pickup coil, but why would it crap out at the same time I changed the ignition coil?
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
