Oil pressure gauge bouncing
Car: 86 Iroc
Axle/Gears: GU5 323
Just trying to figure out why my oil pressure gauge bounces? 86 Iroc, 305 tpi, It will stay steady for a couple of sec then it bounces up and down then back to normal.....Thanks for any and all help
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Oil pressure gauge bouncing
see what happens with a mechanical gauge. i had a metal shaving get into a main bearing a chewed it up and caused the same problem.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Check it out as stated above.Mine has been doing that since I bought the car.Like 7 or more years ago.
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
is it doing this in while stopped in drive? They will bounce a little bit if your at lower rpms, maybe 5psi or so. It should be steady under a load, could be a bad connection too
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
I replaced the gauge in our shop truck for the same problem and the bouncing went away
Oops, meant to say sender
Car: 86 Iroc
Axle/Gears: GU5 323
Yes, it only does it at idle. Under throttle it seems to be steady. I just had tach/oil gauge recalibrated . Bad connection where? Could it possibly be oil p/s switch?
Car: 88 GTA Trans-am
Engine: 350 vortec TPI(in process)
Transmission: 700-R4
Axle/Gears: 3.27 LSD
check the sending unit. if it is a TPI there will be a solenoid by the distributer, it looks like a fuel filter, its a $10 fix and takes 2 mins to change. my oil pressure dropped to nothing. i changed it and had no further problems
Car: 91 CAMARO RS v6 78 c10 350
Engine: 3.1
Transmission: 5 SPEED
Axle/Gears: stock
sounds like u need a oil pressure switch. i had the same thing with my 91 camaro. u can check it by if you have a new oil pressure switch on hand. unplug ur old one and plug it into the known good unit and ur oil pressure should be at 0psi cuz it not bolted to ur block. if it reads 0 even when u rev ur car then its you oil pressure switch.
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
The safest thing to do is ck it with a known good mechanical guage.It could be the sender,bad guage,bad ground,loose connections.It could also be the relief spring in the pump trying to stick.If it cks good w/ a mechanical,you know it's external,sender,wires,etc.It shouldn't cause drivability issues tho.
Just change out the sending unit.
Don't bother with a mech gauge. All you will end up finding out, most likely, is that it needs a sending unit. 90% probability or greater.
Meanwhile, if changing out the sending unit doesn't fix it, then you still don't need a mech gauge, because now you can trust the factory one. BUT, you're only out $15 and a coupla minutes work, instead of whatever dinking around a mech gauge would have required.
THINK: 90% probability, $15, 30 seconds, EEEEEEEZY, car is FIXED; compared to .... what?
Oil pumps basically don't fail in these engines. Springs don't stick. It just simply ISN'T anything to do with the oiling system itself.
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
ambainb
Apr 25, 2016 09:21 PM
