rebuild 305
rebuild 305
I have a 305 I got bored out .030 now I need to know what to buy. Would like to get more performance out of it but not so much that I need to change the computer,so any help would be appreciated.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: rebuild 305
Factory rebuild, K&N filter and exhaust then DONE
Re: rebuild 305
I will try this one part at a time I guess, now that everyone has had their fun. How do I figure out what piston to use. I need a parts list, as you can tell this is my first time rebuilding so true help is needed here. I guess if I do need to change the computer so be it.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: rebuild 305
more details of the car,transmission,axle ratio,carb/injection used,performance expectations, will be needed before any recommendations can be done
for the pistons,cast flattops will likely be good enough-be aware that inexpensive"rebuilder"pistons usually sit about .030 or more down in the cylinder.
for the pistons,cast flattops will likely be good enough-be aware that inexpensive"rebuilder"pistons usually sit about .030 or more down in the cylinder. Thread
someone972
Aug 30, 2015 12:52 AM
