Help smog my car??? Code 32
Old Feb 21, 2014 | 05:09 PM
TipTricky's Avatar
Car: 1991 Chevy Camaro Z28
Engine: 5.7lt TPI L98
Axle/Gears: Drum Brakes, Not Sure Gears
I have a code 32 on my 1991 Chevy Camaro 5.7 TPI. I replaced the egr valve and air intake temp sensor as well as tested the solenoid to make sure its working right. I was checking vacuum to the solenoid and there is non so i pulled the line off the bottom of the throttle body and it seem that port is in front of the throttle plates which has no vacuum.
Is this where the line should go?
Should it be on the black or the silver vacuum port on the solenoid?
Is the egr open with no vacuum?
Anything i should check?
Old Feb 21, 2014 | 06:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help smog my car??? Code 32
The egr works off a ported vacuum signal. it sounds like the solenoid is bad. Iirc it should ohm at 28 ohms.
Old Feb 21, 2014 | 06:53 PM
TipTricky's Avatar
Hey tuned im sure your annoyed with my questions. When sending power to the solenoid it closes through one port and the other port is open like the new one i bought. Should it not be like that?
Old Feb 21, 2014 | 06:58 PM
TipTricky's Avatar
If it ohms at 29 im assuming it is still good then?
Old Feb 21, 2014 | 07:12 PM
Engine: Lb9
Transmission: M20
The operation to vent is correct the passage is normally open. The solenoid is pwm during operation and may have failed during decel or cruise.
Last year I helped a member! he replaced the egr and solenoid and ecm? He was still getting the code 32 so I disabled it with reprograming.
Is your nox high ?
Old Feb 21, 2014 | 07:33 PM
TipTricky's Avatar
So even if it ohms and opperates correctly when bench testing it it might still be bad? If thats the case thats fine ill replace it but if it doesnt need to be id rather not hack up the harness to put the connector on for the new solenoid. Also i have not had a test run because the light is on and that is an aromatic fail.
Old Feb 21, 2014 | 07:45 PM
Engine: Lb9
Transmission: M20
Old Feb 21, 2014 | 08:10 PM
TipTricky's Avatar
I guess ill be removing the egr and cleaning the ports any reccomendations on how to clean then well?
Old Feb 22, 2014 | 10:09 AM
Engine: Lb9
Transmission: M20
look at the passengers side runner and plenum for extreme build up in the small tube in the runner and the ports behind the throttle body in the plenum. You dont need to clean it so its down to aluminum just remove the large pieces and make sure the passages are clear.
Old Feb 22, 2014 | 05:52 PM
TipTricky's Avatar
Should air be able to pass through the egr exhaust port on the intake that the egr bolts to? I tried blowing air into the round hole where the egr bolts to to see if it would blow out through the exhaust but air will not go through is that normal or is it blocked/plugged?
Old Feb 22, 2014 | 05:59 PM
Engine: Lb9
Transmission: M20
The round hole goes into the pass cylinder head into the heat crossover. Yes if you blow compressed air into the passage it will go into the exhaust .
Old Feb 22, 2014 | 06:09 PM
TipTricky's Avatar
So if i use the air compressor at about 90 psi and air does not pass through its safe to say i found the problem?
Old Feb 22, 2014 | 06:25 PM
Engine: Lb9
Transmission: M20
Bump the engine over and try it again. I can't remember what exhaust valve the air goes into but if its closed air won't pass..
Old Feb 22, 2014 | 06:37 PM
TipTricky's Avatar
Well i bumped the key twice which fired it up with the intake off haha woops but no change still cant pass air through it
Old Feb 22, 2014 | 11:44 PM
TipTricky's Avatar
Well i pulled the intake and found the problem... The egr passage was plugged with about and inch of carbon build up.
Getting intake hot tanked in the day light hopefully.
onefreakz
May 14, 2018 12:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 7, 2015 09:55 PM
