Making Noise/Wont Start
Old Feb 27, 2014 | 04:02 PM
noeg92's Avatar
Car: 1988 Camaro 305TBI Iroc Base
Engine: 305 TBI
My 88 camaro 305 tbi isn't starting. It is making a weird noise from the timing belt. The belt isnt moving and it seems like its stuck and makes a loud noise if the moving mechanism was stuck. I need help with figuring out this issue. I have a video of what is going on but I can't post it since it is too big.
Old Feb 27, 2014 | 05:47 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Making Noise/Wont Start
https://www.thirdgen.org/forums/tech...formation.html
If the belt isn't moving the engine is not turning over on the starter so you need to figure out why before you do damage.
Start by pulling all the spark plugs out , then try turning
Disconnect the belt and try; maybe one of the accessories is locked up ?
Old Feb 27, 2014 | 05:59 PM
noeg92's Avatar
Engine: 305 TBI
The noise appears to be coming from the alternator. it makes a loud cranking sounds and the belt moves like 1/8th and returns back. I had changed the fuel injectors on the car and accidentally left a towel by the timing belt and turned on the car and it got stuck so I took out the towel and tried again and the noise started happening. Before I replaced the fuel injectors it wasn't making it. I know messed up with leaving the towel.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mizz0313
Aug 12, 2015 06:45 AM
