Car wont start
Old Mar 2, 2014 | 12:39 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Car wont start
Very happy yesterday because after nearly 5 years rebuilding my car, it was back on the road. Ive had it running since last year, done about 20 miles today.
So.....went to start for about the 10th time today, nothing whatsoever. Didnt even try? It can be a little hesitant when hot.
Heres what Ive got
406ci Procharged motor, Holley 700cfm blowthrough carb,
Ive checked the MSD ignition, all ok. Distributor visually appears ok.
Fuel pressure set at 7psi on a Aeromotive boost referenced regulator.
Car smelled heavily of gas after repeated cranking.
Im guessing at something along the lines of the fact that the vibration from being back on the road has dislodged some dirt or sealer in the fuel system???
Please any help or ideas would be great
Old Mar 2, 2014 | 12:42 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Re: Car wont start
are you getting fire to the plugs, is the coil getting power, is the fuel coming out of the squirters when acceleration is applied?
Old Mar 2, 2014 | 12:45 PM
Car: '92 RS Camaro
Transmission: TH400
Re: Car wont start
Ive left it for tonight, going back tomorrow, I find a rest helps think better. You can do a test with an MSD to check coil output, thats all ok. Not checked the carb yet. The puzzling thing is, ive had that engine running stationary for hours many times, only now when the car is back on the road this happens?
Re: Car wont start
is the engine even turning over when you turn the key? if not check wires at starter, do you have heat shield around starter? Excessive heat can destroy a starter, I have a 355 with a 6-71 blower it builds enough heat, I went through 3 starters before I realized what was up, installed a heat blanket around the starter and no more issues with the starter.
Old Mar 2, 2014 | 12:46 PM
Re: Car wont start
ok let me know what you find
Car: '92 RS Camaro
Transmission: TH400
Re: Car wont start
Oh it cranks over very well, just not even a hint of starting?
Old Mar 2, 2014 | 04:39 PM
John62591's Avatar
Car: '83 Camaro Z28 5.0, '93 Camry 3.0
Engine: 305 V8, V6 DOC
Re: Car wont start
Spray some carb cleaner through the carb and see if it wants to start after that, If it does you may want to check the fuel system/air filter/clogged carburetor, if not then you should check for spark to your plugs if you can.
Old Mar 2, 2014 | 04:58 PM
saldav420's Avatar
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
Re: Car wont start
Does your camaro have a IAC sensor(idle air control)?
Old Mar 6, 2014 | 12:54 AM
John62591's Avatar
Re: Car wont start
Let us know what you find..
Old Mar 6, 2014 | 06:05 AM
Car: '92 RS Camaro
Transmission: TH400
Re: Car wont start
Car does fire up eventually, The ignition is all new and works fine, carb is squirting gas, fuel pressure now set at 7psi, was down at 4?? Although gauge isn't great, going to get a new one. I can only think of maybe vapour lock, I will get a spacer
Old Mar 6, 2014 | 03:41 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Car wont start
You stated up top "smelled heavily of gas after repeated cranking" so it doesn't appear to be a fuel supply problem ; rather a Ign problem
When it won't fire up, I would be pulling plugs out.
Dry plug ; no fuel
Wet plug ; no spark
FWIW ;
if the squirters are working as you say then they should supply enough gas it get it to fire up and purge any vapour out of the line to the tank
If vapour in the line is proven to be the problem a elec pump at the tank will fix that
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
