Installing rocker arms
Old Mar 2, 2014 | 01:37 PM
pontiacdog's Avatar
Car: '86 Trans Am
I did my first valve job and replaced the cylinder head gaskets and now I'm re-assembling the engine back together.
Is there something that I should know about installing rocker arms + pushrods? I was about to simply bolt the rocker arms back in place but then I remember something about rotating the engine until the 1st cylinder is in its TDD or something like that.
My setup is a stock '86 305 TPI machine.
The engine has been rotated a few times but the camshaft and timing chain are untouched.
Old Mar 2, 2014 | 03:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Installing rocker arms
When the lifter is on the base circle of the cam, you tighten the rocker down to zero lash. You then tighten the rocker an additional 1-4 to 1/2 turn. That sets a preload inside the hydraulic lifter.
Old Mar 2, 2014 | 07:35 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Maybe it was Alky who previously mentioned making the nut tighter again if it feels loose by tapping it some with a hammer (off the stud of course!) to close up the top end a bit. Was a saver for me. Don't hit it too hard though - too tight and it's won't back off the stud and you've created another problem...
Old Mar 2, 2014 | 08:35 PM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
This is from the shop manual.
File Type: pdf
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
