Engine Electrical Question
Old Mar 2, 2014 | 08:37 PM
rayount's Avatar
I need some help. I have an "extra" wire/connector that I can't figure out needs to be reconnected.
1985 T/A with TPI and Auto trans:
I took the front end apart to replace the harmonic balancer. When I put it back together, I now have a connector that I can't for the life of me figure out the destination. The car runs fine and has since I put it back together. Except the A/C doesn't work, although the wiring is connected.
The wire is on the driver side, above the rocker cover and beside the TPI runners. I think it is brown/white, although I don't exactly recall. It has a white round connector. It is heading toward the A/C compressor & power steering pump, although it isn't long enough. It looks like it almost want to go under/to the throttle body.
I have reviewed the wiring diagram and can't seem to find that combo of wires or any function that isn't working.
I am baffled. Any help would be great.
TIA,
Ron
Old Mar 2, 2014 | 10:30 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Engine Electrical Question
Check the back of the AC compressor for a missing connector.
A picture of the connector would help quite a bit.
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
