L69 Dual Snorkel Temp Vacuum Switch
Car: 1987 GTA
Engine: LB9
Axle/Gears: 10 bolt 3.23
Hello all,
I searched around for info on this but haven't come across a clear answer. I recently repainted my newly acquired L69 Dual Snorkel but didn't think to take a note on how this part goes on so hopefully you guys can tell me. I just want to know if I have this Temperature Vacuum Switch (I believe) on right? I know the vacuum hoses are on right so I just need to know the orientation of the TVS. Thanks
-Ryan
-Ryan
Re: L69 Dual Snorkel Temp Vacuum Switch
It appears it is installed correctly, with the element inside the air cleaner housing and the lines routed properly. I believe the connection of the lines is not a significant issue since the TVS is a simple valve with no checking or vent action, but you'll know as soon as it gets warm.
Transmission: 5-Speed Manual
It Looks Right,I'll Pull My Lid Tomorrow And Check.
You Have It Right.
You Have It Right.
Car: 1987 GTA
Engine: LB9
Brinkkl2000
Aug 4, 2018 08:29 AM
ambainb
Apr 25, 2016 09:21 PM
86IROC112
Aug 17, 2015 02:00 PM
