Installing intake manifold
Car: '86 Trans Am
I've heard so many people having to redo the installation so I'm planning to get it right the first time.
The new gaskets came with a tube of sealant for the front + back rails on the engine block. Do I let the sealant sit for 15 minutes before dropping the intake on it, or do I specifically have to drop the intake on it immediately and complete the job under 5 minutes?
Also, I've heard I should use some sealant on the gaskets themselves. Do I spread it all around the gasket or just on the coolant passages (1 front + 1 back)?
Car: 1983 Z28
Engine: 385 Fastburn
Re: Installing intake manifold
These are good directions, from JEGS:
-Use only recommended intake gaskets set when installing this intake manifold.
- Fully clean the cylinder head intake flanges and the engine block end seal surfaces.
- Apply Edelbrock Gasgacinch sealant PN 9300 to both cylinder head flanges and to the cylinder head side of the gaskets, allow to air
dry, and attach the intake gaskets.
- Do not use cork or rubber end seals. Use RTV silicone sealer instead. Apply a ¼" high bead across each block end seal surface,
overlapping the intake gasket at the four corners. This method will eliminate end seal slippage.
- Install the intake manifold and hold-down bolts. On applications with pre-1995 cylinder heads, apply a small amount of silicone to
the threads of the eight inner bolts (1,2,3,4,5,7,9 & 11 in Figure 2) to prevent oil weepage, as generally these are not blind holes
in the cylinder head. Torque all of the manifold bolts in two steps by the sequence shown in Figure 2 to 25 ft/lbs.
- Install the intake manifold and hold-down bolts. On applications with Vortec or E-Tec cylinder heads, torque all of the manifold bolts
in two steps by the sequence shown in Figure 3 to 11 ft/lbs
taken from this link:
http://www.jegs.com/InstallationInst...0/350-2701.pdf
Car: 1983 Z28
That's how mine was installed, been on there for 7 years w/no issues.
Car: 83Z28 HO
Transmission: G Force 5 speed
There's plenty of ways to install the intake....different sealants...etc.
The above instructions sound pretty good. Not too difficult, but it can be botched like anything else if you rush it. Just the fact that you're asking tells me you want to do it right..
Making sure both the intake gasket sealing surfaces on both the head and intake are fully clean can't be over-emphasized...they gotta be clean. Doesn't hurt to spray a rag with carb cleaner and give both surfaces a full wipe down. Any old oil residue will prevent the sealer from sticking.
I use the liquid type thread sealer on the bolt threads mentioned above. Sometimes if you don't seal the threads, you could end up with small puddles of oil sitting on your intake...not good.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Actually, I don't even recommend using RTV. Go and buy a product called the Right Stuff made by Permatex. It's the best stuff to use for end rail sealant. When compared to RTV, it's not cheap but it's far better than RTV in the long run.
Car: '86 Trans Am
Ok, I got the job done. Picture here:
http://aijaa.com/img/b/00294/13106980.jpg
I thought I did a good job with the sealants and all but I have two concerns:
1. As I was focused on the sealants and their curing time, I forgot to install the little bracket next to the thermostat housing. Should I risk breaking the seal and remove those 2 bolts or should I just not install the bracket? It's supposed to hold the fuel lines in place.
Same thing happened with the EGR solenoid.. but I'm not running EGR anyway.
2. The sealant on the gaskets squeezed out when I torqued the bolts. It's probably going to block the coolant passages a little from the edges. Is this a problem?
Car: 83Z28 HO
It would take one heck of a lot of sealant to block the cooling passages...
Car: 1986 Trans Am
Thats what I use to! The stuff works great, and it comes in a cheeze wiz looking can and is easy to apply. A mechanic friend of mine told me about it, he uses it all the time on he problematic GM V'6s. He's done dozens of them and has never had one leak using the Right Stuff.
86IROC112
Aug 17, 2015 02:00 PM
