Help Car Dies after driving
Old Mar 13, 2014 | 08:15 PM
xxpotandaxx's Avatar
Car: 1992 Camaro z28
Engine: 5.0 TPI
Transmission: 5 Speed Manual t5
i have a 1992 camaro z28 305 TPI I just bought it ,anywaysI can drive it for about 2 hours then after like beating on it going not even that fast like 80 , it just bogs out and dies and if i step on the gas it dies even faster i've tried replacing the thermostat and all new hoses and ive tried replacing the throttle position sensor and im running 93 gas ,im almost out of money now and ideas has anyone ever had this problem or does anyone have any ideas? Could not having my temperature sensor hooked up cause this issue? because i noticed its not hooked up ?
I replaced the TPS No luck with that
Old Mar 15, 2014 | 07:48 AM
Vader's Avatar
Re: Help Car Dies after driving
Did you replace the catalytic converter when the exhaust was replaced? If your temperature sender is connected, you might be able to see if the engine is heating as it loses power, and that would be a clue.
Old Mar 16, 2014 | 09:34 PM
Engine: 5.0 TPI
the catalyst converters could be old old its hard to tell i just bought the car and i guess it passed massachusetts inspection in 2011 last
Old Mar 16, 2014 | 11:03 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i'd try the fuel filter. sure cant hurt to change it.
Old Mar 17, 2014 | 07:15 AM
Engine: 5.0 TPI
Awesome lol i thought it could be that to so i ordered one
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 17, 2015 02:00 PM
