Header Collector Flange gasket continues to leak; Would it be ok to double up gaskets
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Hey all im awaiting my Ebl flash this tuesday and im attempting to tighten down all "loose ends" that i have. One of them is a Pesky exhaust leak at the driver side header's collector flange. I had a really shitty exhaust job done and they did a crappy job welding together to the header so the Flange gasket blows out really fast. Any ways New headers are here and (soon to be) cat back system so im getting rid of my crappy exhaust system, BUT for now i still want to get started tuning with Ebl and i know i need to get rid of this exhaust leak for my O2 sensor. Any ways would it be a bad idea to double up the gasket at the flange so that it seals good? Basically if i put a new gasket in it seals and the exhaust leak goes away for a month or more. Then it becomes its usual very AUDIBLE sound. It sounds like a tractor it sucks.The Passenger side has no problems and it looks like on the driver side it would work perfectly.... But some one let me know!!
Re: Header Collector Flange gasket continues to leak; Would it be ok to double up gas
If you've got the usual 3-bolt flanges, you could put FIFTY gaskets in there, and they'll still fail.
A better plan would be a set of these. http://www.summitracing.com/parts/flo-15930/overview/ They make em in several different size combos.
Car: 87 iroc-z
Engine: 454
Transmission: th350
autozone carrys these now. might be worth a shot?
http://www.summitracing.com/parts/php-66002/overview/
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
since you are looking for a temporary fix, you could try some red rtv on both sides of a normal cheapo 3 bolt gasket. It wont last forever, but might last you until you swap.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Sep 8, 2015 03:38 PM
NinjaNife
Aug 23, 2015 11:49 AM
