88 tbi 5.0 305 camaro
Old Mar 17, 2014 | 07:51 PM
Kman68's Avatar
Car: 88 "shorty" camaro
Axle/Gears: Stock
Same ole story, let sit for a cpl years and won't crank, will if fuel directly in tbi.fuel filter? Anyone with same prob and a solution?
Kman
Old Mar 18, 2014 | 01:32 AM
mauijerky's Avatar
Car: 91 RS
Axle/Gears: Stock w/ 3.73 posi
Re: 88 tbi 5.0 305 camaro
When gasoline sits for too long, it will gradually become solid. If this is the case then most likely the fuel pump in the tank has seized and/or clogged fuel filter. How much fuel was in the car during the duration of not being used? New fuel pump and filter is a definite. Although, you might need to remove all remaining old fuel and flush out the fuel lines. It depends on how much the old gasoline dried up and solidified.
Old Mar 21, 2014 | 01:58 PM
Kman68's Avatar
Axle/Gears: Stock
Not hardly any. The pump is building pressure in tank. I have heard that it needs at least half a tank to prime properly. I'm not sure how true that is though
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
dutch930
Sep 11, 2015 06:58 AM
Randomtask2
Aug 13, 2015 01:57 AM
