auto rear hatch
Old Mar 24, 2014 | 03:29 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
auto rear hatch
Can anyone tell me how the two prongs in the hatch that touch the metal plate work and where the wires run..... Or does this have nothing to do with hatch and just provides power to Third brake light ..
Old Mar 25, 2014 | 10:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: auto rear hatch
That should only be power for the brake light.
Old Mar 25, 2014 | 10:16 AM
Engine: 5.7 l98
Re: auto rear hatch
OK thanks. So my next question would be, what connection makes the motor run in the down position. Thanks again
Old Mar 25, 2014 | 11:20 AM
Engine: 5.7 l98
Re: auto rear hatch
just installed new reverser switch and when connected the motor runs to up position but does not go down when closed. first time fixing it (trying) in 18 years lol
Old Mar 25, 2014 | 11:47 AM
Engine: 5.7 l98
Re: auto rear hatch
ok so I went out and looked again there is a plastic switched that gets pushed when trunk is closed. my motor not running down when closed so I am assuming the relay is the problem. I will update when done.
Old Mar 25, 2014 | 12:38 PM
Engine: 5.7 l98
Re: auto rear hatch
update .....so while testing the relay I blew the fuse which is wired up above the fuse box above driver side kick panel
Old Mar 25, 2014 | 01:27 PM
Engine: 5.7 l98
Re: auto rear hatch
replaced fuse and pick up new relay while there still not working I have power on the red and white , power on one leg of relay , and power at one terminal that plugs into motor when I check at each point... any ideas ??????
Old Mar 26, 2014 | 01:48 PM
Engine: 5.7 l98
Re: auto rear hatch
Old Mar 29, 2014 | 12:52 PM
Engine: 5.7 l98
Re: auto rear hatch
ok so sorry for the rambling .. I was frustrated .. took it all apart moved motor up shaft a bit and changed position of reverser switch. it WORKS...
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
