timing question
Old Mar 26, 2014 | 07:10 AM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
timing question
I have an 91 rs 305 auto...an it seems to idle too high....its throttle body also so whats the normal idle for these cars? bcz it seems like my timming might be set up by the previous owner but it idles too high an pulls on its own
Old Mar 26, 2014 | 09:52 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: timming question
A typical idle (when in drive) would be somewhere between 650 and 750 I believe. I have my 350 set up to idle at about 675 in drive.
Is it staying in fast idle after warming up or something?
Old Mar 26, 2014 | 10:06 AM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
yea I can start it up an it idles real high it comes down to bout 1000 or over when in drive its at 1000 it never gets below 1000 which makes me believe the timin has been messed with by the previous owner
Old Mar 27, 2014 | 08:00 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I would be more willing to bet you need to replace the TBI base gasket.
Old Mar 28, 2014 | 12:17 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: timing question
u think so? wut makes u think that?
Old Mar 28, 2014 | 12:34 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: timing question
A vacuum leak could be possible so PO raised the idle speed to compensate.
best thing to do is rule out any vacuum leaks, make sure the IAC motor is OK, then reset the idle speed
to specs.
of course you can check base timing... unplug the tan wire from the dist. and then set base timing to "0" or you can set it advanced a couple of degrees.
Old Mar 28, 2014 | 02:54 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: timing question
It use to have a vacuum leak under the dash for the heater but other than that I don't think it has a vacuum leak now an how do u reset the idle speed?
Old Mar 28, 2014 | 05:22 PM
FRMULA88's Avatar
Car: 1988 Formula
Re: timing question
ummm ahhh with the idle speed screw ? is this a trick question?
Old Mar 28, 2014 | 07:49 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: timing question
I had to buy a Innova digital timing gun # 3568 with RPM display to properly set timing and min. idle speed using the correct IAC motor reset procedure to finally get it right.
=https://www.thirdgen.org/tpimod2
I found mine on line for $65.00
I already have the standard timing light but is worthless compared to the upgrade.
= http://www.oreillyauto.com/site/c/de...&keyword=+3568
Old Mar 29, 2014 | 07:44 AM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: timing question
i have read that u cant just change the idle without having to go through a whole procedure...sorry if im behind ive never had or tried to set the idle on a throttle body engine its always been carb ive set em on
Old Mar 29, 2014 | 05:24 PM
Engine: TBI,5.0
Re: timing question
What I mentioned above is the procedure.
The digital timing gun allows you to adjust exactly to "0"*stock timing setting and then go through the IACV reset and then adjust the min. idle speed .
You can’t adjust something you can’t see like the RPMs. That's why I bought the new timing gun.
Not only is it more accurate when setting your timing but shows exactly where the rpm are.=
Amazon.com: INNOVA 3568 Digital Timing Light: Automotive Amazon.com: INNOVA 3568 Digital Timing Light: Automotive
Old Aug 26, 2014 | 07:26 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: timing question
How do I set the timing is there a thread on here about it? Can someone post a link to it or tell me how to.... An where is the aldl connector so I can set my iac valve?
Old Aug 26, 2014 | 09:03 PM
Engine: TBI,5.0
Re: timing question
The previous owner could have advanced the base timing a little. As you turn the distributor advancing the base timing the RPMs will increase. If that's the case all you have to do is back it down to the stock setting of "0"
Is there a reason you want to reset the IACV ?
There is a thread concerning setting timing but I cant seem to find it.
Old Aug 27, 2014 | 03:25 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: timing question
yea when my car is warmed up an I put it in drive it idles about 1000 in park almost at 1500 I kno my tach is a lil off also but that's the reason why im thinkin I might need to reset it
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
