Fuel in exhaust/surging idle
Old Mar 27, 2014 | 12:41 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I have not driven my camaro in the last few years. I have run it on occasion just to keep everything primed but not that often. Last summer the car wouldn't start and it turned out the injectors were clogged. I replaced the injectors and spark plugs and the car runs but not very well. It starts fine but after idling for a minute the idle get a little rough and the revs will dip and surge for a while until it inevitably stalls. Also it makes the entire garage smell like a gas tank. My first thought would be egr but I am open to other opinions.
Old Apr 9, 2014 | 02:59 PM
jstuart83's Avatar
Re: Fuel in exhaust/surging idle
I too am having the same issue have you discovered anything?
Old Apr 9, 2014 | 05:13 PM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Transmission: auto/stock
Axle/Gears: stock
Ditto but maybe not running quite rich as yours.. but you can smell it.. Today I tried to get the damn IAC off and couldn't.. I tightened back down to where I thought it was and now the car won't idle when it's cold, I need to keep my foot on the gas a little until it warms up.. and now the car is idling at 950-1000 when warm.. that seems high, it used to idle at 750.. hopefully my mechanic can fix it tomorrow.. I'm getting the proper memcal 350 as it currently has a 305 in it when my engine is a 350.. I did NOT do this.. lol
Old Apr 10, 2014 | 10:32 AM
Car: 92' RS
Engine: LO3
Not yet. I took the erg off and cleaned out the passages as best as I could. The diapram seems to be working properly. I just got the gasket so I am goign to reasseble it and see if that made any difference. I doubt it will though. I need to check for any vac leaks next since they are what 22 years old now. I will let you know if I find anything.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Logan Bryant
Aug 27, 2015 11:52 AM
