Injector Height Difference, Will they Work?
Old Apr 10, 2014 | 08:26 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am currently installing siemens 60 lb injectors in place of my Bosch III 30 lb injectors. The siemens are about 1/8" shorter in height when measuring from o ring to o ring. Would I just be able to remove the washers that you use on the aftermarket tpi intakes to bring it down and make these work?
Old Apr 10, 2014 | 09:15 PM
Re: Injector Height Difference, Will they Work?
Yup; might have to grind down a bit off of the little boss things that they sit on too, but it doesn't take much.
If you make sure the little clip things are on the fuel rail end, the manifold end is ALOT less critical.
1992rs/ss
Jan 31, 2025 05:10 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
