Smoking Exhaust
Old Apr 10, 2014 | 09:38 PM
MikailLoewen's Avatar
Car: 1988 Iroc-z
Transmission: 5 Speed Std
Smoking Exhaust
I recently replaced the exhaust system on my car including the Cat. When i start the car it runs normal no smoke but smells weird, and it seems once it starts too warm up it will start smoking blueish smoke. if you rev it it comes out of the deceleration. I know that my valve stem seals need to be replaced on the car would this be the problem? I was also getting code 33 and 34 for the mass airflow, could the valve stem seals cause it too give those codes? or is the mass airflow the cause of the smoking. I replaced the mass airflow a couple of years ago. thanks
Old Apr 11, 2014 | 08:43 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Smoking Exhaust
as for parts store MAFs .I personally have been through 8 different ones. they are all re-man in CHINA!!(never buy anything that says "a1 cardone" on the box) and they are junk. I ended up buying one from my local GM dealer for.....$1100 no less.and blue smoke on decel is an indication of what you already know,time for a valve job on those heads.and no, the MAF doesent cause blue smoke.plenty of black when they die ,but no blue
Old Apr 11, 2014 | 11:14 AM
Car: 1988 Iroc-z
Re: Smoking Exhaust
I was looking at my MAF and thought it looked pretty cheap for the price. I'll bring her down too the mechanic and see what he says about the MAF thing, and if he could get me a good quality mass airflow. Thanks for the help!
Old Apr 11, 2014 | 11:23 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Smoking Exhaust
A word of advice: DON'T DO THAT. Your mechanic will hose you big for a knock-off that will burn out quick.
Search eBay. You might get lucky and find a NOS or other new GM MAF for dirt cheap (I got my $280 MAF for $50, NIB).
And then you need to examine the air intake and find out why the MAF sensors keep burning out.
Old Apr 11, 2014 | 04:16 PM
Car: 86 IROC
Engine: 5.0 TPI
Re: Smoking Exhaust
it takes a very expensive flow bench type thing to accurately test a MAF. I would suggest a NEW one .certainly not a re-man one. (made of chinesium!)
Old Apr 13, 2014 | 11:43 AM
spdhawk77's Avatar
Car: 89 Formula
Engine: 305 T.B.I.
Transmission: 5 Speed Manual
Re: Smoking Exhaust
definately gas/air prob. valve seals normally just puff a bit of white smoke when first started due to oil settling in the head when not running..
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
69GTOby
Apr 18, 2016 02:34 PM
84redta
Sep 19, 2015 09:58 AM
Accerrito22
Sep 5, 2015 09:34 PM
