cam upgrade
Old Apr 11, 2014 | 08:52 PM
spdhawk77's Avatar
Car: 89 Formula
Engine: 305 T.B.I.
Transmission: 5 Speed Manual
cam upgrade
i think im gona have to replace my 305 timing chain. im wondering can i go with a slightly bigger cam while im at it? can i just throw a bigger cam in and put her back together or will i have to do other upgrades to accept the bigger cam?
Old Apr 11, 2014 | 09:17 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: cam upgrade
Depends on how much bigger of a cam your talking about. Valve springs are a necessary upgrade you will have to do if you put a cam in with around .440, .450 lift. Since you will be removing all the accessories anyway, a cam is a worthwhile upgrade. Changing the valve springs is also a good time to replace valve seals which usually cause smokey startups if their original. A lot of people like to run an lt1 cam as a cheap upgrade in roller 305s and 350s.
Old Apr 11, 2014 | 09:26 PM
spdhawk77's Avatar
Car: 89 Formula
Engine: 305 T.B.I.
Re: cam upgrade
thanks.. i dont want to do anthing extreme just a little extra something while im digging around in there. my seals need replaced anyway i know. what would be the biggest cam i could go without having to replace alot of extras or throwing off the computer. id like to get just what i can get away with without rebuilding the engine or really hurting my gas milage..
Old Apr 11, 2014 | 09:43 PM
Eric-86sc's Avatar
Engine: 305, 355
Re: cam upgrade
Comp cams makes a 249h that is claimed to be computer friendly. It is mild but would be a decent upgrade over your stock cam. You would get away with not changing valve springs. A few other cams I would recommend would be an l98 or g92 cam. Obviously a tune would help increase performance but i do not think its necessary to make the car run decent. Whatever cam you choose it has to be 112 degrees lobe separation or higher to work with the computer.
Old Apr 11, 2014 | 10:22 PM
spdhawk77's Avatar
Car: 89 Formula
Engine: 305 T.B.I.
Re: cam upgrade
than you for the intel. i will check out the cams you mentioned. the more ive sat here and thought about it im considering having the heads reworked while im at it. i know my valve seals leak and cant justify going through the trouble of replacing them without reworking the heads. im curious, do you know if i can get that cam out and new one in without pulling engine? just remove the radiator etc? even the nose if nessecary..
Old Apr 12, 2014 | 01:56 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: cam upgrade
if your gonna rebuild the heads you might as well upgrade to at least vortec heads .
Old Apr 13, 2014 | 06:54 PM
spdhawk's Avatar
Car: 89 Formula
Engine: 305 TBI
Axle/Gears: Stock
Re: cam upgrade
okay.. this is just so i can find this info when i delete my other account that i didnt realize i had til now.. haahaahaa!!
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Stryker412
Sep 7, 2015 09:11 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
