Possible sensor issue need help
Old Apr 20, 2014 | 08:08 PM
BlueV6's Avatar
Car: 85 Camaro
Engine: 2.8L.....for now
So i picked up an 85 V6 recently for 800 runs for about 10 miles then shuts off the guy said it might be a sensor from what ive researched so far i figure it could be either MAF sensor or Ignition control module just looking for other opinions or if anyone has had this problem
Thanks in advance
Old Apr 20, 2014 | 10:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Possible sensor issue need help
Only way way to know.
Pull the engine fault codes and report back what you find
https://www.thirdgen.org/forums/tech...s-dumbies.html
There are other (physical ) things that can cause your problem but you need to confirm it is not computer ( sensor ) related 1st
Cornholio7979
Sep 20, 2018 02:31 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
beast94
Aug 20, 2015 06:44 AM
mdtoren
Aug 16, 2015 05:45 PM
