idle surging problems.
Old Apr 26, 2014 | 11:40 AM
visitor's Avatar
Car: genesis, equus, f250, camaro, other
Engine: 5.7
Transmission: t5
I have a 1992 camaro rs, with a t5, and a 350 from a 1989 Chevy truck, tbi injection.
I purchased it as it sits, so im unaware of when it was done. Start off by saying what I do know-
Every sensor related to the car running is new, all test fine.
No check engine light appears (and yes, it DOES work properly)
Car runs strong at throttle, no pings, knocks, or other noises, sounds, smells)
Car has NO cats, or O2 sensors
Gauges read off, mph is about 15 mph fast, rpm around 600 off, temp is WAY off. Fuel and voltage, oil pressure SEEM accurate.
Injectors are cleaned, functioning normally
Fuel pressure is ok, not the issue
No vacuum leaks
Appears to be factory computer (305).
Doesn't matter the temperature, or the amount of fuel in the tank.
Now, here's the rundown of the problem..
Car constantly surges at idle, going from 500ish to 1500ish, constantly. Runs down the road fine, no surging. Car will not die when doing this.
Car DOES occasionally die when pushing in the clutch at speed, press in clutch, rpms immediately drop down, most time it catches itself, sometimes no. Seems to happen more frequently when doing things like turning off an off ramp. Car will immediately restart (except one exception seen below)
It has happened ONCE that after dying, car would not restart for 45 minutes or so, then it started normally.
If you upnplug one sensor or another it will usually temporarily alleviate the issue, but not always, and not always the same sensor.
Any ideas? Shop that its at now seems to think it could be the computer not "talking" to the engine correctly, as its thinking its a 305. Thoughts? Other ideas?
Could it be
Old Apr 27, 2014 | 07:28 AM
Vader's Avatar
Re: idle surging problems.
No vacuum leaks
Does that include the EGR, PCV, and brake power booster?
Is the IAC functional? Is TPS voltage correct and stable?
Old Apr 28, 2014 | 12:50 AM
visitor's Avatar
Engine: 5.7
Transmission: t5
Yes, those are included.
Yes iac is NEW, and functioning, tps is new as.well, and correct and stable.
Old Apr 28, 2014 | 01:06 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tbi/...l-350-tbi.html
Old May 1, 2014 | 06:09 PM
visitor's Avatar
Engine: 5.7
Transmission: t5
I think this is the issue.. I need the computer out of a vehicle with a 350 and 5 speed...I was thinking like a 89 silver ado 2wd.. Will that work?
Old Jul 29, 2014 | 08:18 PM
visitor's Avatar
Engine: 5.7
Transmission: t5
As a finish to whoever may find this while searching- it was the computer giving me fits. THANK YOU to those who helped provide a resolution
MM2Robinson
Oct 1, 2017 09:16 AM
IROCtometal
Sep 20, 2015 11:08 PM
banksGTA
Sep 13, 2015 11:56 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
