83 Z-28 windshield wiper problem
Hope I'm in the right category , but with my luck, likely not ! Anyway new spring problem with the wipers .Turn on fine, low and high fine, no delay and wont shut off . UNTIL you shut the car off , then they shut off and sink down where they should be when you restart the car. ... any tips or suggestions ? Thank you ! Bob
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: 83 Z-28 windshield wiper problem
My '82 Recaro T/A just started doing this too. If you pull the black plastic cover off the motor there is an electronic circuit board. I have a feeling something failed on it.
Car: 1983 Z28
Engine: 385 Fastburn
Mine does this too, I had actually almost forgotten since I don't drive it in the rain, haha. You just need to replace the circuit board, or the entire motor (with circuit attached), whichever is easier.
Car: 83Z28 HO
Transmission: G Force 5 speed
I had a similar issue too. Turn on the wipers and they didn't shut off unless I shut the whole car down and restart it. But- my speeds and delay worked.
I replaced the switch on my steering column and it's fine now.
Thanks for the replies guys . Will check on the board 1st .. have to see if its easily removable , may see if I can have a look at the solder joints and resolder.. if not go for the motor, thanks again , Bob
Car: 83Z28 HO
If you find out the circuit board is bad, check out rebuilt washer pumps for a delay system. I believe they come with new boards attached. About 50-60 bucks though.
colton_carlson
Mar 8, 2019 12:21 PM
