need custom prom?
Old May 3, 2014 | 09:43 PM
acerulz's Avatar
Car: 1984 Cadillac Brougham
Engine: 1989 Iroc Z 350
need custom prom?
Just installed vortec heads, performance plus cyclone intake, tbi adapter and throttle body spacer to my 350 tbi. Engine has a mild cam in it, and headers with dual 2 1/2 pipes. Engine runs great around 6 degrees, but can't get rid of a power loss when I slam the gas down. It falls on its face and backfires through the intake. If I don't slam it down and just moderately go to WOT it keeps up but just doesn't seem to have as much power as it should have. I bumped up the regulator to 15 psi also. Wondering if I have to put 454 injectors in it, or if I should get a custom burn prom for it? If I go prom, how can I tell what my cam specs are without a cam wheel? Any good sites for a custom prom? thanks in advance!
Old May 3, 2014 | 11:20 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need custom prom?
https://www.thirdgen.org/forums/tech...formation.html
Pulled the engine fault codes ?
https://www.thirdgen.org/forums/tech...s-dumbies.html
https://www.thirdgen.org/forums/post...781-post4.html
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dusterbd
Sep 29, 2015 08:40 AM
