Help identifying hoses.
Old May 4, 2014 | 05:26 PM
okayaj's Avatar
Car: 1985 Camaro
Engine: V8 350
My car is stalling out at stoplights and idling very roughly. I was able to find a hose hanging down under the passenger-side front wheel, but I can't see where it comes from. Extensive Googling says this is a vacuum hose and I have a vacuum leak messing up my idle, but I can't see where this hose is supposed to go.
I found another identical hose not connected to anything up near the carb, but the two hoses don't seem to fit together.
1985 Camaro z28, swapped in V8 350 w/ cam, carbureted, automatic.
Here's a few pictures I took, really tough to get near where that hose comes from though.
http://imgur.com/a/VXMCy#0
Second hose:
https://i.imgur.com/SexTn4J.jpg
Old May 4, 2014 | 06:28 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Help identifying hoses.
Who did the carb swap ?
Many redundant hoses after swap
If the hose does not directly connect to the intake or carb it is not your current problem
racereese
Oct 10, 2015 09:39 PM
Linson
Sep 21, 2015 01:08 PM
Tweeks25
Sep 17, 2015 08:04 AM
abrilnelson89
Sep 16, 2015 02:19 PM
89 formula TPI
Sep 7, 2015 10:19 AM
