1989 iroc z 350tpi HELP
Old May 4, 2014 | 06:22 PM
trailerparkking's Avatar
Car: 89 iroc z
Engine: 350 tpi
After driving for 5 mins, its starts cutting out when I put a load on it. If I hold the throttle sounds like it wants to die out almost like it isnt getting fuel? Anyone else have this problem need some help here I put a high velocity fuel pump and bigger fuel rails and it didnt get rid of it and does anyone know the stock flow rate on the injectors?
Old May 4, 2014 | 06:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1989 iroc z 350tpi HELP
https://www.thirdgen.org/forums/tech...formation.html
https://www.thirdgen.org/forums/tech...s-dumbies.html
Is not like a carb engine ; the fuel is controlled by the computer programming
Your changes have little effect on the fuel supply
More important ; What is your fuel pressure @ the rail ?
22lb
Old May 4, 2014 | 09:14 PM
Car: 89 iroc z
Engine: 350 tpi
Ill check tomorrow just bought the car 2 days ago and a 15hr trip with no sleep has left me no time to tear into it too busy catching up on sleep. What would be a good set of injectors to get and what would be a good flow rate for them? Sorry im somewhat of a newbie only 17 so this is my first rodeo with a vehicle like this!!!
Old May 4, 2014 | 09:27 PM
Car: 89 iroc z
Engine: 350 tpi
What Should I be reading for fuel pressure? And my radiator is spanked too could this have something to do with my problem? Its wicked boggy after I give it a hot supper a few times temperature gauge stays right where it should but maybe the thing dont work and shes just getting too hot. Im gonna replace a few things and see what it does i read up on here and most people say its like 4 or 5 things and they are all cheap fixes. Ill do her up good and see how shes feeling after I give her a little love.
Old May 5, 2014 | 08:32 AM
TX-SleeperC5's Avatar
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
Question for you..... when it's cutting out abd you hold the gas pedal down to keep it running, is there a ton of smoke coming out of the exhaust ??
Old May 5, 2014 | 02:14 PM
Car: 89 iroc z
Engine: 350 tpi
No smoke and if I hold the gas pedal it wants to cut out if I let off it goes to a high idle
Linson
Aug 31, 2015 04:52 PM
Roblyons
Interior Parts Wanted
Aug 30, 2015 12:07 PM
kyleb24
Aug 15, 2015 08:24 AM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
mustangman65_79
Aug 11, 2015 03:17 PM
