new engine smoke issue
Old May 6, 2014 | 07:29 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
my build, rhs head, holley stealth ram, xr276hr cam, 26lb injectors. tune from my previous engine with a hot cam and tpi.
probably has 50 or so miles on h/c/i. no smoke at idle/cruising, at wot i get what appears to be white smoke, i cant really tell if its blue or white since im moving. could this be from a lean condition in my tune? or am i leaking oil/coolant from somewhere. this only happens at WOT
Old May 6, 2014 | 08:19 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: new engine smoke issue
a pressure test of your cooling system will reveal a leak,if you have one. a compression test will reveal the condition of your engine. also the look of your plugs will tell you about that too
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
