header gasket keeps blowing out
Old May 10, 2014 | 12:18 AM
brokencomputer's Avatar
Car: 89RCLBk1500,91bird,99grandam gt
Engine: tbi350,frankenstein tpi 350,3400sfi
Transmission: nv3500,t5,4t45
Axle/Gears: 3.42,not sure,also not sure
i have an 89 chevy truck 350 tbi that i put shorty headers on and it blew out the paper pacesetter gasket they cam with and blew out a percys performance dead soft aluminum one after that. the passenger side is fine with only paper one whats the deal
Old May 10, 2014 | 12:21 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: header gasket keeps blowing out
header bolts have a nasty habit of loosening.there are locking bolt kits,and copper gaskets that solve the problem. but first id take them off and lay a straight edge across the mounting flanges .if they aren't perfectly flat,you can have a machine shop mill them till they are. that should do it for you
Old May 10, 2014 | 12:29 PM
i seem to have gotten them to seal for right now any way put bead of hi temp copper rtv on a new gasket and put it on, seems alot better now. and yea i think i fergot to re torque after driving.
Old May 10, 2014 | 01:33 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
1" long bolts, anti-seize on threads and a fel-pro 1405 gasket.
Old May 10, 2014 | 01:54 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
are they flat? header flangers are often to thin, with heat n time they don't clamp/seal well.
Old May 10, 2014 | 02:33 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Originally Posted by Gumby
are they flat? header flangers are often to thin, with heat n time they done clamp/seal well.
^^THIS^^
There is no gasket that will reliably seal cheap thin warp-prone header flanges. Ultra Copper RTV is your friend there.
However, if you have quality thick header flanges, then the most durable seal I've found is the embossed steel shim gaskets like GM uses for stock manifolds. You can use those and just add the hole(s) necessary for your header bolt arrangement.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Accerrito22
Sep 5, 2015 09:34 PM
90formulaVortec
Sep 3, 2015 09:26 AM
