what kind of engine?
Old May 20, 2014 | 07:52 PM
rusty2400's Avatar
Ok I'm thinking about getting a new engine in my 1989 iroc z camaro with a 305 tpi should be stock. Because it's just not what I was looking for hp wise, how do I find out if it is a crate engine?
Old May 20, 2014 | 08:42 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: what kind of engine?
I'm not sure what your asking? Sounds like you want to know if the 305 in your iroc was replaced with a crate engine.
Old May 20, 2014 | 09:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Easiest way to find out if it's original or not is to check the casting numbers. If casting numbers match the year range and model of the car then check the suffix number. If the number has been machined off then the block has been decked. If the number doesn't match any know VIN or suffix numbers then it's probably a rebuild with custom stamping that only means something to the machine shop that did the work.
If the partial VIN on the block by the suffix number matches the last digits of the VIN of the car then it's the original engine.
Old May 21, 2014 | 07:45 AM
rusty2400's Avatar
I guess what I'm really asking is if I swap the engine in my and let's say it's a crate engine does it matter if I put in another crate engine? Or would it hurt if I don't?
Old May 21, 2014 | 07:49 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Old May 21, 2014 | 08:08 AM
red rock's Avatar
Car: 1987 iroc
All a crate motor is, is a block thats been clean inspected and machined ready to install. So, you can install a crate motor, or a junk yard motor, or buy a new motor from GM. It doesn't matter, just do not install a Ford motor in a GM car, that's against TGO's law's.
Old May 21, 2014 | 08:09 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Taking out an engine and putting in a new one does not hurt the old engine.
jhawkeye
May 25, 2022 06:33 PM
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
