No Spark, Everything New
Car: 1991 Camaro Z28
Engine: 5.0 305 TPI
Transmission: 5-Speed
Alright so to start with I have searched this forum numerous times and read all threads I have come across with a description of no spark/no start and have not found a fix.
I just replaced the head gaskets on my LB9 and made sure all electrical connectors were being plugged in as I went.
New ignition system parts:
Distributor
Coil
Plugs (wires coming tomorrow)
All fuses have been checked as GOOD (even the 20A by the battery)
I even went as far as replacing the ECM because of how desperate I am to get this car back on the road.
The coil is getting voltage:
Battery/system voltage to the grey wire and the same on the pink wire.
I have hooked a spark plug straight to the coil and cranked it to see if I could get anything out of the coil and nothing.
I have hooked the coil and dizzy together with only the #1 cylinder plug hooked to the dizzy and the plug out of the block to see spark and nothing.
I removed the dizzy cap and had a friend crank the car and the rotor spins while cranking.
I also went and removed the ICM from the dizzy and replaced it with the original which yielded the same no spark results.
Also, at KOEO the security light goes out after 3 seconds (good VATS system) and after a quick flash, the SEL light is steady on (good PROM).
I am currently at a complete loss for what the problem could be. ANY help would be GREATLY appreciated as I have run out of ideas here.
Thank you!!
Distributor
Coil
Thank you!!
Car: 88GTA
Engine: 5.7TPI
Re: No Spark, Everything New
I'll give a shout out.
You had the heads removed. Did you re-attach the ground strap to the block and firewall? Just something to check. grounds, grounds, grounds!
Engine: 5.0 305 TPI
Yes sir!! Triple checked all connection to the block. The 2 on the passenger head and the one on the driver's head are all nice and snug.
Can't see any loose/not connected wires anywhere when I look.
Thanks for the reply!
Car: 88GTA
Engine: 5.7TPI
Humm......if it ran before you fixed the gaskets, you must of forgot/missed a few connectors. Check the 2 connectors that go to the ignition control module on the distributor. Those had to be disconnected to take it all apart, and to pull the heads.
I'm just pulling ideas here. There's really not much electrical to be disconnected when doing that job.
Engine: 5.0 305 TPI
Sadly I've triple checked all connections I can see and reach. I have no idea what is causing it to not fire the plugs.
Thanks for your ideas
EDIT: Just remembered... When I pulling the engine apart I removed what was left of the smog/A.I.R system (the black box by the A/C compressor) due to the previous owner having removed the cats and the smog pump. The connectors for the box I pulled out are sitting up under the intake manifold to keep them out of the way. From what I read before I made the decision to remove the system is the car should still run fine without it.
This is the change to the car that has been made and it ran perfect before the head gasket blew.
Car: 88GTA
Engine: 5.7TPI
Did you try this...
KeyOn- Unplugging the 4 pin connector at the dist and quickly touching +12v to the ppl/wht wire terminal should make the injectors pulse (once) and the pump briefly run (about 2 seconds, same as prime). If this is true, then you may have a dead ignition module in the distributor.
Did you check for codes?
Engine: 5.0 305 TPI
Well I've already replaced the distributor with a new (came with new ICM) and thinking the new ICM was DOA I replaced that with the original one I took off the old dist. but I can still do this test for you.
+12v to the harness side or dist. side?
Also, I do not have a scanner so I'm unable to retrieve any codes. But it would be unlikely that I could retrieve any anyway due to the battery having been unhooked 3 times through this troubleshooting process and also due to an ECM replacement that just went in an hour ago.
EDIT: Picture of the distributor to see if you can find anything wrong with it.
Car: 88GTA
Engine: 5.7TPI
Harness side
The pic looks like a 5.0 305 rotor, which looks fine to me
If you don't have a scanner, try this trick. The are are tips all over the board on how to do this:
https://www.thirdgen.org/service-eng...ht-error-codes
Try starting the call as normal. Then if it don't start, try this trick. It may or may not set a trouble code. If it does, I'll bet it will be in the:
Code 42. Fault at electronic spark timing circuit OR Fault at direct ignition system OR Fault at fuel cutoff relay circuit You need to call out to Vetteoz on here.
I'm at a loss.
I'm at a loss.
Engine: 5.0 305 TPI
Alright well I plugged one end of a wire into the purple/white terminal on the harness and touched the other end to to positive terminal on the battery. Nothing happened.
Also, I have the SEL blinking the sequence talked about in the tutorial but how do I decipher what code it's giving out?
Thank you for your help thus-far. Really appreciate it!
EDIT: After watching it flash the sequence in the tutorial for about five minutes I have to say that there are no codes present in the ECM.
Car: 88GTA
Engine: 5.7TPI
OK, one more....
Why did you change the dizzy??
Have you checked Pickup Coil in the distributor. Try this
To test the pickup coil, first disconnect the white and green module leads. Set the ohmmeter on the high scale and connect it between a ground and either the white or green lead. Any resistance measurement less than infinity requires replacement of the pickup coil.
Testing Pickup coil-Test 1 should read infinite at all times. Test 2 should read a steady value of(NNN) NNN-NNNNohms.
Pickup coil continuity is tested using an ohmmeter (on low range) between the white and green leads. Normal resistance is 500-1,500-. If a vacuum unit is used, move the vacuum advance arm while performing this test. This will detect any break in coil continuity. Such a condition can cause intermittent misfiring. Replace the pickup coil if the reading is outside the specified limits.
If no defects have been found at this time, and you still have a problem, then the module will have to be checked. If you do not have access to a module tester, the only possible alternative is a substitution test. If the module fails the substitution test, replace it.
Forgot about that.
Forgot about that.
Engine: 5.0 305 TPI
I replaced the dizzy because the original was rusted beyond belief. It actually made me wonder how exactly spark was able to travel anywhere.
I did the pickup coil test and I got a reading of 876 Ohms which seems to be within tolerance going off of the paste you did below your post.
Also received an infinity reading when going from ground to green and then ground to white.
Car: 88GTA
Engine: 5.7TPI
Then it moves on to the next code, if any. If not, it goes back to the 12 1 FLASH...2 FLASH .
As I said, there are several post on here on how to read codes, just got to look and search a bit. You'll get there, these guys have a lot of knowledge.
Its just hard for me to understand that you have this issue by just replacing head gaskets.
Engine: 5.0 305 TPI
It just kept doing this over and over:
flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause
Yeah trust me, I know the confusion haha. Too bad it's turning into frustration as well.
Car: 88GTA
Engine: 5.7TPI
Well, you got familiar with the Code 12
Car: 88GTA
Engine: 5.7TPI
1982 – 1992 ECM Trouble Codes For Camaro &
Firebird
Code Problem
or Description Possible
Causes
No
reference pulses to ECM.
(All)
This
code should flash whenever the “test” terminal is grounded
with the ignition on and the engine not running.
If
the engine is running and the code appears, this indicates that the
ECM is not receiving any references from the distributor.
Faulty
or loose EST connector at the distributor.
Oxygen
sensor circuit
(All)
Sticking
or misadjusted TPS
Faulty
wiring and/or connectors from the oxygen sensor.
Faulty
oxygen sensor.
Coolant
sensor circuit
(All)
If
the engine is experiencing overheating problems, rectify before
diagnosing further.
Faulty
or loose wiring and/or connectors from the coolant sensor.
Faulty
coolant sensor.
Coolant
sensor circuit
(All)
See note for code 14.
Faulty
Faulty
coolant sensor.
Faulty
or loose wiring and/or connections at the ECM.
21
Throttle
position sensor (TPS) circuit
(All)
Sticking
or misadjusted TPS plunger.
Faulty
or loose wiring/and or connectors at TPS and/or at the ECM.
Faulty
TPS.
22
Throttle
(All)
TPS
misadjusted.
Faulty
Faulty
TPS.
23
Mixture
control (M/C) solenoid circuit
(1982 to 1984 vehicles)
Faulty
or loose wiring and/or connections at the M/C solenoid and/or at the
ECM.
Faulty
M/C solenoid.
23
Manifold
Air Temperature (MAT) sensor
(1985 and later vehicles)
Faulty
MAT sensor.
Faulty
or loose wiring and/or connections to the MAT sensor.
24
Vehicle
speed sensor (VSS) circuit
(All)
A code 24 should only be set while the
vehicle is in motion. Disregard
code 24 if set when drive wheels are not turning.
Faulty
TPS
misadjusted.
Faulty
VSS.
25
Manifold
Incorrect
voltage level of signal from the MAT sensor to the ECM.
Should be above 4 volts
32
Baro
sensor circuit
Short
between sensor terminals B and C or faulty wiring therein.
Faulty
or loose wiring and/or connections at the ECM (Terminals 1, 21 and
22).
Faulty
Baro sensor
32
EGR
system
Faulty
EGR valve.
Faulty
or loose wiring and/or connections at the EGR solenoid.
Faulty,
loose and/or leaking vacuum hoses to EGR valve.
32
Digital
EGR circuit
(1985 and later 3.1L V6)
Faulty
EGR valve.
Open
or short to ground in EGR valve circuit.
Faulty
or loose wiring and/or connections of EGR circuit.
33
Manifold
Absolute Pressure (MAP) sensor
(All 1988 and later TBI V8, 1990 and
later TPI V8)
Low vacuum sensed
Faulty
or disconnected vacuum hoses.
Faulty
Faulty
MAP sensor.
33
Manifold
Absolute Pressure (MAP) sensor circuit
High
signal voltage, low vacuum.
Engine misfire and low unstable idle can set
code 33.
Faulty
or loose wiring and/or connections in the sensor circuit.
33
Mass
Air Flow (MAF) sensor
(1985
to 1989 vehicles, MPFI V6 and TPI V8)
Excessive
airflow indicated.
Incorrect
voltage level at
terminal C on the MAF sensor. Should
be 0.5 volts at idle, 4.7 volts at wide open throttle (WOT)
Faulty
or loose wiring and/or connections at the MAF sensor.
Faulty
MAF sensor.
34
Vacuum
sensor circuit
Faulty
or loose wiring and/or connections at the ECM (Terminals 20, 21 and
22).
Faulty
vacuum sensor wiring and/or connections.
Faulty
vacuum sensor.
34
Manifold
(1988 and later TBI V8, 1990 and
later TPI V8)
High
vacuum sensed
Faulty
Faulty
MAP sensor
34
Manifold
Low
signal voltage, high vacuum
Faulty
An intermittent open will set code 34
34
Mass
(1985 to 1989 vehicles, MPFI V6 and TPI V8)
Low
airflow indicated.
Incorrect
voltage level at terminal C on the MAF sensor.
Should be 0.5 volts at idle, 4.7 volts at wide open throttle (WOT).
Faulty
Faulty
MAF sensor.
35
Idle
Air Control (IAC) circuit
(1987 to 1989 vehicles, MPFI V6 and
TPI V8)
Closed
throttle engine speed is 125 RPM above or below desired (commanded)
idle speed for 45 seconds.
See
a dealer service department for trouble diagnosis.
41
No
distributor signals
Faulty
or loose wiring and/or connections at the distributor.
Faulty
or loose wiring and/or connections at the pickup coil.
Faulty
vacuum sensor circuit (see code 34).
41
Cylinder
select error
Terminal
D3 of ECM not properly grounded to engine.
Faulty
or loose wiring and/or connections to the ECM.
42
Bypass
or EST problem
(All)
If
vehicle will not start, check wire leading to ECM terminal 12.
An
improper HEI module can cause this code.
43
Electronic
Spark Control (ESC) system
(All)
Faulty
or loose wiring and/or connections to ECM terminal L.
Faulty
or loose wiring and/or connections from the ESC controller to the ECM.
Faulty
or loose wiring and/or connections from the knock sensor to ESC
controller.
Voltage
at ECM A-B connector terminal B7 should be over 6 volts unless the
system is sensing detonation.
Faulty
ESC sensor and/or module.
44
Lean
exhaust
(All)
On
carburetor-equipped vehicles:
Faulty
or sticking mixture control (M/C) solenoid.
Faulty or
loose wiring and/or connections at the ECM, terminals 9 and 14.
Vacuum
leakage at carburetor base gasket.
Faulty
or loose vacuum hoses.
Faulty
or leaking intake manifold gasket.
Air
leakage at air management system-to-exhaust ports and at decel valve.
Faulty
oxygen sensor.
On
fuel injection vehicles:
Faulty
Incorrect
fuel pressure.
Faulty
or leaking throttle body gasket.
Faulty
Faulty
Water
in fuel.
Faulty
oxygen sensor.
45
Rich
exhaust
(All)
On
Faulty
or sticking mixture control (M/C) solenoid and/or wiring.
Fuel
in evaporative charcoal canister and its components indicate rich
condition exists.
Faulty
oxygen sensor.
On
Faulty
Incorrect
fuel pressure.
Leaking
fuel injectors.
Intermittent
bursts of fuel from the injectors at idle indicate a faulty TPS.
Faulty
oxygen sensor.
46
Vehicle
Anti-Theft System (VATS)
(1985 and later 3.1 V6)
Ignition
key and/or starting procedures incorrect.
Open
or short to ground in the VATS decoder module circuit.
Should
be checked by a dealer service department if engine does not turn
over.
51
PROM
problem
(All)
The
PROM is located inside the ECM and is very delicate and easily broken.
An authorized mechanic should do all diagnostic procedures.
PROM
not properly installed in the ECM.
Faulty
PROM.
Faulty
ECM.
52
Fuel
CALPAK
CALPAK
PROM not properly installed.
Faulty
PROM.
53
System
over-voltage
(1985 and later vehicles, except
5.0L carbureted)
Voltage
at ECM terminal B2 is greater than 17.1 volts for two or more seconds.
Faulty
charging system.
53
EGR
control error
(1985 and later 5.0L carbureted)
Faulty
or loose wiring and/or connections to EGR solenoid.
Faulty
or loose vacuum hoses to EGR valve.
54
Mixture
Faulty
or loose wiring and/or connections from M/C solenoid to ECM.
Faulty
M/C solenoid
54
Fuel
pump circuit
Voltage
at terminal B2 is less than 2 volts for 1.5 seconds since last
reference pulse was received.
Faulty
fuel pump relay, circuit and connections.
Faulty
oil pressure switch.
55
Oxygen
sensor circuit
Faulty,
loose or corroded wiring and/or connectors at the ECM.
Four-terminal
EST wiring harness too close to electrical signals such as spark plug
wires, distributor housing, alternator, etc.
Faulty
or loose wiring and/or connections of various sensors.
Faulty
oxygen sensor.
55
ECM
Faulty
ground connections to ECM.
Faulty
ECM.
61
Degraded
oxygen sensor
Faulty
oxygen sensor.
Firebird
Code Problem
Causes
No
(All)
This
If
Faulty
Oxygen
sensor circuit
(All)
Sticking
or misadjusted TPS
Faulty
Faulty
oxygen sensor.
Coolant
sensor circuit
(All)
If
diagnosing further.
Faulty
Faulty
coolant sensor.
Coolant
sensor circuit
(All)
Faulty
Faulty
coolant sensor.
Faulty
21
Throttle
(All)
Sticking
Faulty
Faulty
TPS.
22
Throttle
(All)
TPS
misadjusted.
Faulty
Faulty
TPS.
23
Mixture
Faulty
ECM.
Faulty
M/C solenoid.
23
Manifold
Faulty
MAT sensor.
Faulty
24
Vehicle
(All)
Faulty
TPS
misadjusted.
Faulty
VSS.
25
Manifold
Incorrect
32
Baro
sensor circuit
Short
Faulty
22).
Faulty
Baro sensor
32
EGR
system
Faulty
EGR valve.
Faulty
Faulty,
32
Digital
EGR circuit
Faulty
EGR valve.
Open
Faulty
33
Manifold
later TPI V8)
Low vacuum sensed
Faulty
Faulty
Faulty
MAP sensor.
33
Manifold
High
code 33.
Faulty
33
Mass
(1985
Excessive
airflow indicated.
Incorrect
voltage level at
Faulty
Faulty
MAF sensor.
34
Vacuum
sensor circuit
Faulty
22).
Faulty
Faulty
vacuum sensor.
34
Manifold
later TPI V8)
High
vacuum sensed
Faulty
Faulty
MAP sensor
34
Manifold
Low
Faulty
34
Mass
Low
airflow indicated.
Incorrect
Faulty
Faulty
MAF sensor.
35
Idle
TPI V8)
Closed
See
41
No
distributor signals
Faulty
Faulty
Faulty
41
Cylinder
select error
Terminal
Faulty
42
Bypass
or EST problem
(All)
If
An
43
Electronic
(All)
Faulty
Faulty
Faulty
controller.
Voltage
Faulty
44
Lean
exhaust
(All)
On
Faulty
Faulty or
Vacuum
Faulty
Faulty
Air
Faulty
oxygen sensor.
On
Faulty
Incorrect
fuel pressure.
Faulty
Faulty
Faulty
Water
in fuel.
Faulty
oxygen sensor.
45
Rich
exhaust
(All)
On
Faulty
Fuel
condition exists.
Faulty
oxygen sensor.
On
Faulty
Incorrect
fuel pressure.
Leaking
fuel injectors.
Intermittent
Faulty
oxygen sensor.
46
Vehicle
Ignition
Open
Should
over.
51
PROM
problem
(All)
The
PROM
Faulty
PROM.
Faulty
ECM.
52
Fuel
CALPAK
CALPAK
Faulty
PROM.
53
System
over-voltage
5.0L carbureted)
Voltage
Faulty
charging system.
53
EGR
control error
Faulty
Faulty
54
Mixture
Faulty
Faulty
M/C solenoid
54
Fuel
pump circuit
Voltage
Faulty
Faulty
55
Oxygen
sensor circuit
Faulty,
Four-terminal
Faulty
Faulty
oxygen sensor.
55
ECM
Faulty
Faulty
ECM.
61
Degraded
oxygen sensor
Faulty
oxygen sensor.
Engine: 5.0 305 TPI
So pretty much everything looks okay?
Everything at the distributor is perfect. In-fact I just went and fine-adjusted the cap to be more in-line with the rotor on firing order. Still nothing.
EDIT: I just did a continuity test of the ignition coil through the main power connector. Reading I got was 0.5 Ohms
Also did a distributor ground check by going from the dizzy body to the engine block. Reading I got was 0.4 Ohms.
I did the dizzy check following instruction from a post on CarJunky.com posted in 2008. This is what it said:
I also probed the 4-pin dizzy connector with a test light with the key on. Not sure if there be power going through the harness but I didn't get anything from all 4 wires.
Next; test if either of the wires are shorted to ground. Connect one meter lead to one of the pick-up coils wires and the other lead to the distributor housing; it should show open (no connection). Then do the other wire; it also should be open.
Last thought and while you have the ohmmeter out; is check if the distributor has a good ground. Connect one lead to the distributor housing and the other to the engine block; there shouldn’t be any more then 3 or 4 Ohms.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
This is just an outside the box idea, but since the problem started after the head re&re, you have tothink something went wrong on installation. If my memory is any good, I believe the 2 pin connector at the distributor uses the same connector as the IAT connector on the bottem of the plenum. Not sure if they are even long enough to be interchanged, but it might be worth a check. What color are the wires on the external 2 pin connector going in to the ignition control module, pink/white or tan/black?
Car: 88GTA
Engine: 5.7TPI
Engine: 5.0 305 TPI
The 2-pin connector going to the dizzy is tan/black.
I have uploaded a picture for you as well.
Thanks for all the help guys!
HUGE Edit:
Absolutely amazing! Can't believe I switched those two connectors!! After staring at an ignition system wiring schematic for near 3 hours I never caught on to the mistake I made.
I've got spark!! No I need to get it to actually start. I get a pop every now and then so I think the timing is WAAAAY off right now.
Thanks for all your help guys!! Wouldn't have been able to find the issue without you!
For anyone that finds this thread in the future, this wiring diagram is a big help. Just look CLOSELY haha.
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Thanks again!!
HUGE Edit:
Thanks again!!
Car: 88GTA
Engine: 5.7TPI
HUGE Edit:
Thanks again!!
HUGE Edit:
Thanks again!!
Engine: 5.0 305 TPI
Lol well at least I'm not the only one
Time to take the plugs out and see how the timing is. Not gonna be easy due to having hooker headers that are in the way of the plugs haha.
Will update when that's finished!
UPDATE (Not finished):
Pulled the valve covers, saw cylinder 5 at TDC (both valves closed) and the dist. rotor point at terminal #8. I think it's safe to say that my timing is definitely off haha.
Gonna pull the dist and set it pointing at #5. See if that helps.
UPDATE 2:
Got it! Still won't start because I think I've drained the battery of a good amount of CCAs lol but when cranking (which it does slowly) I can pops coming from each cylinder in-time and can smell it firing (which is an amazing smell btw lol)
Time to put the battery on a 15 amp charger for a couple hours and try again!
Well I think I've narrowed the slow crank speed down to a failing starter which I n\knew was going bad a while ago (only way to start the car sometimes was with a bump start due to stuck starter armature).
So I went and searched for symptoms of a dying starter motor and low-and-behold I found this:
I am facing all the problems they've listed in that quote. A LOT of chugging with all of my interior lights and instrument panel lights going VERY dim.
Time for a starter!
UPDATE 2:
Originally Posted by eHow
Listen for a chugging sound while cranking. While a certain amount of chug is normal, particularly at low cranking speed, a chug accompanied by dimming and brightening lights may indicate a mechanical failure in the motor's bearings. If this is the case, you may be able to get by for a while by hitting your starter with a hammer from underneath in order to break the starter shaft loose. But, probably not.
Time for a starter!
Engine: 5.0 305 TPI
She has come back to life!!!
After getting a battery that's actually worth a d***, it was able to crank with enough force to actually fire up and run.
I had to dial in the timing a bit but it wasn't too difficult once I found which piston was at TDC and setting up the rotor to be a bit after that terminal on the cap. Setting the rotor up that way was the key to get it to run!
Started and ran the first time I did that and after a little fine tuning with moving the dizzy body around so the ICM connectors were closer to the firewall she got to idling on her own with no shaking what-so-ever!
I'll upload a video once my friend comes over and acts as the cameraman lol.
Thank you eseibel67 for the help and pointing out my mix up with connectors and 1RAMAIRWS6 for the support and help through this project!
Check back for the video later tonight!
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
