Possible VATS issue? 89 IrocZ 5.7 Auto
Old May 23, 2014 | 06:54 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Transmission: TH-700R4
Axle/Gears: 2.77
Ok well to start I have
1989 IrocZ 5.7 TPI Auto with all new..
fuel pump, fuel strainer, fuel filter, starter, oil pressure sensor, MAF relay, oil filter, harmonic balancer, timing chain cover, spark plugs, cap, rotor, oil dipstick, belt.
All new gaskets on the bottom end. Used but still good ignition module to coil wire, 700R4 with all new gaskets and kickdown cable. New after market cable selector for trans but it's 1/4 to 1/2 too short. =/
The battery is new but I had been cranking to get the starter going. I finally did, turned out the safety neutral was off and I was able to move the shifter with out the key in. I just dropped the steering columns 2 bolts and moved the shifter back n forth till it fell in place. So it cranked then and I had spark.
Then it was on to the fuel pump to see why it wasn't priming. I took all the relays out to check the harness with a light tester. Harness was good, i put them all back into place. Turned out someone put a 30amp fuse on the harness next to the battery. (it looked slightly melted) Changed it out for a new 20amp. Fuel pump primed and had good pressure. (I put in new o rings at the fuel filter cause it was leaking - fixed-)
But now the starter wasn't cranking and the service engine soon light is on. But and get this, if I take out the 20amp fuse for the fuel pump out and turn the key on the SES light turns off.
So all in all - turn the key - Pump primes - Security light comes on then off - SES Light stays on - No crank.
Any and all is greatly appreciated!!
Old May 23, 2014 | 07:05 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Axle/Gears: 2.77
Re: Possible VATS issue? 89 IrocZ 5.7 Auto
And Im only getting code 12 from the ALDL
Old May 24, 2014 | 02:08 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
VATS may be working fine but if the enable relay operated by VATS is faulty then you have the same effect as a bad NSS
Old May 24, 2014 | 02:09 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Need to check the whole starter circuit from Ign switch to starter solenoid to see where you are loosing power when in the START position
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Dec 6, 2015 11:25 PM
ezobens
Aug 19, 2015 10:29 PM
djmarch
Aug 9, 2015 05:27 PM
