strange ignition
Old Jun 2, 2014 | 05:07 PM
Artic-Trans am's Avatar
Car: 87 TA
Engine: 350 modifyed Stelth Ram
Transmission: 350 rew lock up
Axle/Gears: 9"
strange ignition
i have a (not) funny ignition.
motor runs not very well below 40 degrees ignition.
I have done more than one lamp, but like the lamp where I can adjust setting on the lamp.
ok, so all advise is max 36 degree on around 3000 rpm.
I can easy run with 55...
less than 40 and the motor start to make a "knotting" sound under pressure (like a drag race) sounds not right at all.
Is this anything normal?
my ballanser is new together with the rest of the rotating kit...
compression is around 11
292xfi compcam
bore .060 and stroked.
If anything is wrong, what can it be..
Old Jun 4, 2014 | 02:57 PM
Car: 87 TA
Axle/Gears: 9"
Re: strange ignition
Here I have some video's where I have timing max to 35
can it be ok to advance timing up to 55 max
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
RedLeader289
Sep 23, 2015 06:50 AM
