vbelt to serpentine
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
vbelt to serpentine
ive never looked into it but is there any way to make a serpentine setup work on a set of of heads that dont have the extra bolt holes for it?
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: vbelt to serpentine
You can drill and tap the one passenger side head for the needed bolt, But be careful in how deep you drill and use a stud with locktite. I had the machine shop drill mine while they had them.....
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
that seems sketchy to do with just a drill but yea i guess i see where your going with that. you think thats my only option without spending a fortune on some custom aftermarket brackets and such?
Car: 88 GTA
Sketchy ?
I took the guy at the machine shop my right side bracket, He sat my head on a block laying there with the shim head gasket I'm using. He bolted the bracket to the block and to the one bolt hole already in the head, He then marked for the second bolt. He removed the bracket then sat the head up on his bench and drilled it with a hand held drill, He drilled 5/8" deep then tapped for a 3/8" bolt/stud.
Being careful and watching what your doing, This can be done in the car.
Lets see, Cost of drill bit and tap versus expensive custom aftermarket brackets.....
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
sketchy for me as ive never been very good with drilling into engine components, the idea isnt sketchy the idea is good lol. i think ill talk to a few neighbors with actual machine shop presses and see if the can drill it out at work or something, id feel better with a machine doing it than myself.
evilstuie
Jan 9, 2020 08:29 PM
codeysabatini
Nov 10, 2015 04:07 PM
