Random hesitation and power loss.
Old Jun 17, 2014 | 02:15 PM
AlaskanDad's Avatar
Car: Camaro
Engine: 5.0
On my way to work something happened. Car started fine but coming to my first stop there was some hesitation and power loss. Idle appears a little rough but nothing crazy, and sounds normal. However, once acceleration is needed it feels and sounds like one of my spark plug wires came off. Hood vibrates allot when accelerating and it has never done that before.
Checked my plugs while on break and they were all connected.
Thinking bad injector or possible bad spark plug - it has been throwing code 34 and running rich for a while now.
Any ideas?
Old Jun 25, 2014 | 07:53 PM
AlaskanDad's Avatar
Car: Camaro
Engine: 5.0
Re: Random hesitation and power loss.
Perhaps I did not give enough information.
Anyways, have not replaced plugs yet since it has been raining and cold out. However, my wife did follow me for a drive and she said it smells very rich. Now I am leaning on a bad plug.
Is there anything else under the hood that could prevent proper spark other than bad plugs? Wires, cap and rotor look fine on visual inspection so far.
Old Jun 25, 2014 | 11:08 PM
tyeo098's Avatar
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
Do an ohm test (continuity) on the wires. Make sure that what goes in also comes out.
Did you visually inspect the plugs as well?
Bad engine vibration means something is off balance. A piston not doing its power stroke could be one.
Old Jun 26, 2014 | 12:00 AM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Check and correct your code 34 first. Check your vacuum to your MAP Sensor. You may also have a bad sensor or connector.
sailtexas186548
Aug 24, 2015 10:11 PM
mdtoren
Aug 23, 2015 12:52 PM
db057
Aug 22, 2015 08:17 PM
mdtoren
Aug 16, 2015 05:45 PM
Bradsaundry
Aug 12, 2015 12:34 AM
