GTA 5.7- injectors ? Or is it my ECM? PROBLEM SOLVED!
Old Jun 21, 2014 | 06:26 PM
mper11's Avatar
Car: 1988 GTA
Engine: 5.7 355
Transmission: automatic
After driving 3 or 4 miles in 90 degree weather my car starts to buck, looses power and then stops completely. I have to wait about 30 minutes before it would stay running long enough to get home. I just put in a new MAF thinking it was the issue but it hasn't changed. Any ideas? Car only has 100,000 miles but hasn't been driven much at all in the last few years. The temp gauge stops at 160 degrees.
Old Jun 21, 2014 | 07:44 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: 88 GTA 5.7- could my injectors be getting to hot?
Did you pull any codes yet? That would be the first thing.
Old Jun 21, 2014 | 09:06 PM
ex-x-fire's Avatar
Running the engine at 160 or less isn't the greatest thing to do,(it runs leaner & cleaner at 195*) sounds like you cat converter is plugged.
Old Jun 22, 2014 | 12:55 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
a NEW MAF? or a cheapo re-man one from auto zone? that may well be your problem . man, I bought SEVEN of them before I got wise and bought a new one from "rich porter".
Old Jun 22, 2014 | 01:29 PM
No, the injectors won't do that.
Check the fuel pressure, WHILE IT'S IN THE ACT OF SCREWING UP (not just, sitting in the driveway happily idling)
Fix the temp gauge. Kinda ... risky ... to drive around with a temp gauge that doesn't cover the normal operating range of the thing it's supposed to be measuring.
Old Jun 22, 2014 | 01:34 PM
mper11's Avatar
Car: 1988 GTA
Engine: 5.7 355
I tried pulling codes with a paperclip. And it doesn't even flash 12? Could this mean I have a bad the ECM?
Old Jun 22, 2014 | 02:06 PM
mper11's Avatar
Car: 1988 GTA
Engine: 5.7 355
Even worse I got the MAF off ebay. It came off a GTA that was hit in the rear quarter and then parted out. I have a sneaking suspicion it's the ECM since I can't pull any codes. Is it safe to get one from Auto Zone?
Old Jun 22, 2014 | 04:12 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
What ever you do DO NOT BUY IT from AutoZone. Go to a junkyard and pull one for $17.99
Old Jun 22, 2014 | 05:29 PM
Car: 86 IROC
Engine: 5.0 TPI
I got mine from oreilleys, then I had a custom chip burned.TADAAA! no more problem. and if you do get a re-man ECM....... DO NOT under any circumstances get from auto zone
Old Jun 22, 2014 | 06:44 PM
mper11's Avatar
Car: 1988 GTA
Engine: 5.7 355
Guess it had a re manufactured one in it already.
Attached Thumbnails GTA  5.7-  injectors ? Or is it my ECM? PROBLEM SOLVED!-20140622_194949.jpg   GTA  5.7-  injectors ? Or is it my ECM? PROBLEM SOLVED!-20140622_195001.jpg
Old Jun 22, 2014 | 06:46 PM
mper11's Avatar
Car: 1988 GTA
Engine: 5.7 355
Took out the ECM or ECC and look what I found....
Attached Thumbnails GTA  5.7-  injectors ? Or is it my ECM? PROBLEM SOLVED!-20140622_152649.jpg
Old Jun 22, 2014 | 08:43 PM
Car: 86 IROC
Engine: 5.0 TPI
look, theres a guru on here that does chips ,"tuned performance" he burned my chip as he has done for countless others .he is THE man for the job. light years away from hyper junk. give him a shout. he can help you too
Old Jun 23, 2014 | 02:23 PM
mper11's Avatar
Car: 1988 GTA
Engine: 5.7 355
Thanks I'll do that.
Old Jun 23, 2014 | 02:37 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Tuned Performance does an awesome job! Highly recommended, but you still haven't addressed the "no code" issue......or did you?
Old Jun 23, 2014 | 03:45 PM
mper11's Avatar
Car: 1988 GTA
Engine: 5.7 355
Re: 88 GTA 5.7- could my injectors be getting to hot? Or is it my ECM?
Im getting a new ECM today, im gonna use the old hypertech memcal just to see if I can pull any codes. I do want to get a new chip from Brian @ tuned performance.
Old Jun 23, 2014 | 09:03 PM
mper11's Avatar
Car: 1988 GTA
Engine: 5.7 355
SUCCESS! New ECM did the trick..
Old Jun 24, 2014 | 09:51 AM
mper11's Avatar
Car: 1988 GTA
Engine: 5.7 355
Re: GTA 5.7- injectors ? Or is it my ECM? PROBLEM SOLVED!
Would the ECM be effecting the temp gauge reading? It's now operating at 190-195
Old Jun 24, 2014 | 10:01 AM
Car: 86 IROC
Engine: 5.0 TPI
I think the ECM was effecting the temp gauge reading? It's now operating at 190-195
the ECM has nothing to do with the temp gauge working or not.
bryan623
Mar 22, 2021 06:43 PM
gta90
Sep 15, 2015 04:00 PM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 10, 2015 08:42 AM
