AC Compressor O-Ring
Old Jun 22, 2014 | 10:15 AM
huber16's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
Transmission: Stock 700R4
Axle/Gears: ?? Original
I have found the leak in the AC system on my "91 RS (V6). There is a pressure switch in the back of the compressor. The O-ring on this switch needs to be replaced. I have tried a couple of O-rings with no luck. I need the dimensions of the correct o-ring. Where can I find the correct dimensions I.D., O.D., thickness?
Old Jun 22, 2014 | 11:01 AM
Joe Tag's Avatar
Re: AC Compressor O-Ring
As long as you're going to have the system open on a 23 year old car, why not buy a whole seal kit for it and ward off future problems?
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Old Jun 22, 2014 | 11:07 AM
huber16's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
OK if I get the kit, how do I know which one fits where?
Old Jun 22, 2014 | 11:13 AM
Joe Tag's Avatar
Remove and compare is how I did it.
Old Jun 22, 2014 | 11:24 AM
huber16's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
I've already done that and failed 2 times. I'm looking for exact dimensions or part numbers. Thanks
Old Jun 22, 2014 | 11:45 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I had this same problem.so I went and got o rings with varying thicknesses and used the fattest one I could wiggle in there.problem solved
Old Jun 22, 2014 | 04:09 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If you're still running the stock R4 compressor and I'm assuming you're looking for the o-ring for the high pressure switch, you should be able to find the o-ring you need here:
http://www.rockauto.com/catalog/x,ca...parttype,13290
If this doesn't work for you, you might want to put on your "humble" cap and drop by your local A/C shop with your switch (and the old o-ring if you still have it) and ask them if they have an o-ring that will fit.
Old Jun 22, 2014 | 07:22 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
I did that too just yesterday, had the kit, did a remove and compare. The system took the charge and seems to be holding but now my 25 year old compressor is not engaging like it did last year. I just posted about it too.
gixxer92
May 18, 2017 11:20 AM
jrdturbo
Mar 31, 2016 02:58 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
BOOT77
Sep 5, 2015 03:55 PM
