Bolt On Mods Help!
Old Jul 4, 2014 | 09:58 PM
Formula2208's Avatar
Bolt On Mods Help!
Can anyone help me out and tell me what are some good bolt on mods for my 1989 firebird formula 350?
Thanks!!
Old Jul 6, 2014 | 09:21 AM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
Re: Bolt On Mods Help!
I have a n 89 formula l-98 I have CAI UD pulleys ported runners and plenum airfoil and a chip from pcm of nc seems to run pretty strong never had it at the track but idd run it couple of times with my old g-tech and would run 13.7-13.8 so I would be happy with low 14's at the actual track.
Old Jul 9, 2014 | 05:03 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Thanks!!
Start with
Hooker 2055 or Dyno Don shorty headers (Both come with emissions if you require it where you are) or long tubes for dual exhaust if you have a manual.
If you run single exhaust, same headers as above (Get the shorties), and run 3" catback. Magnaflo's set up is actually very decent. Dual exhaust, run 2.5".
This alone will free up 10-30hp depending on your set up.
After this, it all depends on what you consider bolt on.
Some people consider a new set of heads "bolt on". For some it's a cam swap. Don't buy a "Tuner chip" from a company. Tune your own or take it to a shop that will do it. either way, use a dyno.
I would personally start with a full tune up and exhaust upgrade and go from there.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
TheTraut88
Sep 7, 2015 05:22 PM
FormulasOnly
Sep 6, 2015 10:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
