Starts and then stalls out
Old Jul 11, 2014 | 03:42 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
Hello everyone. I have a 87 gta trans am and the car starts up fine and after a few seconds it stalls out. It's not the vats system because it doesn't have one. The car was running perfect before I took out the upper intake manifold. Could it be a vacuum leak. If I keep my foot on the gas petal it will run but after 9 secs off the gas it would die out and stall. Please help.
Old Jul 11, 2014 | 05:06 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Starts and then stalls out
do you have a TPI car? why did you remove the plenum in the first place? and yes you could have a vaccum leak.go back over all you have done and check
Old Jul 11, 2014 | 09:34 PM
Engine: 5.7 350 TPI
Yes tpi got it to start but it's idling at 3000 rmp now.
Old Jul 12, 2014 | 12:35 AM
Car: 86 IROC
Engine: 5.0 TPI
is your check engine light on while its running? if so check your codes.with the engine off remove the air duct and check if the throttle blades are dirty or being blocked open somehow.your kickdown cable could be kinked/misrouted holding the throttle open. your IAC solenoid could be faulty.your hose leading to the brake booster could be leaking air. re check everything you have done.and you may find your problem.let us know
jklein337
Sep 19, 2018 06:23 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Bryan F
Aug 18, 2015 02:28 PM
