Electric power shuts off when I attempt to start car
Old Jul 19, 2014 | 09:30 AM
87camaro kid's Avatar
Car: 1987 Z28
The car has electric power when I put the key in the ignition but as soon as I attempt to crank it over, I hear a click and all the power shuts off for 30 seconds to a minute and then comes back on. Happens each time I try to start even with jumper cables connected. Battery is less than a year old so I'm not sure what the problem is. Any help is greatly appreciated.
Old Jul 23, 2014 | 07:18 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Electric power shuts off when I attempt to start car
If this happens even with another battery/jumper cables they you probably have a bad battery connection (not necessarily at the battery but somewhere in the main power distribution). Whats happening is as soon as you turn key there's enough of a load where either the battery voltage is loaded down or there is a substantial voltage drop across a connections (leaving nothing significant for your car).
I would measure the voltage at your battery while you try to start the car. If the battery voltage drops, the load is too great for your battery/batteries (indicating maybe a bad battery, starter, or short). If the battery voltage does not drop then you have a bad connection probably at the starter or block.
Old Jul 23, 2014 | 08:11 PM
Clean the batt cable connections. Both ends of ALL cables, AND the batt itself, AND whatever the ends of the cables bolt to. AND, if the cables have the bolt-on ends, take those off and clean the wires AND the connectors.
Did I mention "clean", "ends", "cables", "AND", enough?
Use baking soda and hot water, with a wire brush, as your cleaner.
BRoss99
Aug 10, 2025 05:08 PM
specialized
Jun 18, 2022 09:26 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
