Weird fuel problem
Old Jul 30, 2014 | 01:40 AM
JackMaverik's Avatar
Weird fuel problem
My z28 has a holley 650 on it. When i get about 5 gallons low on fuel it starts behaving like its outta gas.
If i stop and put gas in it, it stops sputtering and stalling.
Its not vapor lock.
Old Jul 30, 2014 | 07:28 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Weird fuel problem
Its not vapor lock.
How do you know it's not vapor lock?
What kind of fuel pump are you running?
With a carb on these cars you have to have a pusher pump, just running the mechanical pump on the engine block will cause vapor lock.
Old Jul 31, 2014 | 02:05 AM
My first thought was vapor lock, so i pulled the gas cap and it still did it. Now i am thinking its a bad fuel line, intermittent pump, or terrible garbage getting stuck in the carb.
Old Aug 3, 2014 | 04:06 AM
It was a clogged fuel filter.
Old Aug 4, 2014 | 06:51 AM
Car: 1983 Z28
Glad you found it, and that it was something simple.
Old Aug 4, 2014 | 11:59 AM
That seemed to have fixed it but now my symptoms are still there. Ill be driving and itll start to die like the gas is cutting in and out. Ugh. This will be the death of me.
Old Aug 4, 2014 | 12:14 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
maybe the pick-up in your gas tank isnt reaching all the way down? did you do away with the in tank electric pump?
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
sreZ28
Aug 14, 2015 07:48 PM
92camaroJoe
Aug 13, 2015 06:07 AM
