Rough idle when first start up
Old Jul 30, 2014 | 11:42 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
When I start my car in the morning or when ever for the first time after sitting all night it idles rough but as soon as it warms up it's perfect?!!? Wth is going on here?
Old Jul 31, 2014 | 10:37 AM
Engine: 5.7 350 TPI
Re: Rough idle when first start up
Anyone? Help
Old Jul 31, 2014 | 10:52 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I'll bite....Have you checked the following:
1. Any Codes?
2. Old or New Injectors?
3. Fuel Pressure readings?
4. TPS Setting?
5. IAC Setting?
6. Timing Setting?
7. Cold Start Injector still hooked up?
8. Cold Start Temp Switch working, (the one at front of intake that controls the Cold Start Injector)?
Is the engine stock, modified, crucified.......you know what I mean.
I could go on but I won't. There's just a lot of variables for "rough Idle"
Old Jul 31, 2014 | 01:47 PM
Engine: 5.7 350 TPI
No codes
Fuel injectors are new (I think)
Fuel pressure is 80 psi
TPS is good checked it
Didn't check timing and iac
I believe the car is running lean at idle too
And when I first start the car in the morning (it about 80 degrees here) it idles at 1000rpm and then it goes up to 1300 and runs perfect but isn't that to high?
When I drop the idle screw the car runs way to rough
Old Jul 31, 2014 | 02:13 PM
Engine: 5.7 350 TPI
Not stock motor
slp runners
Edelbrock heads ( crane rockers)
TCI transmission
Dynomax full exhaust
Old Jul 31, 2014 | 03:24 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
OOOOOOOOOOKKKKKKAAAAAAYYYYY Then........ Well, outta my league.
Old Jul 31, 2014 | 06:09 PM
Engine: 5.7 350 TPI
Anyone else??
Old Aug 1, 2014 | 03:34 PM
Engine: 5.7 350 TPI
The engine light comes on when first start up and then when warmed up and running fine **** off back.
Old Aug 2, 2014 | 07:04 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Are you sure the fuel pressure is 80? That's almost double what a TPI should be.
Old Aug 2, 2014 | 01:29 PM
Engine: 5.7 350 TPI
Well unless my gauge is wrong I'm getting 80 and if I try to drop the pressure it starts to idle even rougher
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Bradsaundry
Aug 12, 2015 12:34 AM
