Fuel filter replacement
Old Aug 3, 2014 | 08:56 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Hi, I am trying to change the fuel filter on my car but the threads seem to be seized. The lines and filter are off a donor car and I don't think the filter has ever been changed in 175k. The threads are rusted and covered by rubberized undercoating.
I got wrenches on the line and filter but they didn't budge. I didn't want to keep trying in case the fuel line flare nut is seized to the line itself and have the end of the line twist off. Done that before.
Any suggestions?
Old Aug 3, 2014 | 11:48 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Fuel filter replacement
Any suggestions?
line wrenches and PB blaster. the correct line wrench+ pb will get the job done. and good luck.
Old Aug 6, 2014 | 03:33 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I would handle this in a couple of stages. First, spray the undercoated fittings with WD40 to loosen it up, use a wire brush to get the big chunks off, then spray again with same or penetrating oil of choice and leave it for a few days. Will come apart real nice.
Old Aug 6, 2014 | 07:07 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
both of those guys are right, a correct size line wrench and some PB blaster is the only way i will attack an old rusty fuel line
Old Aug 6, 2014 | 10:40 AM
BHicks's Avatar
Car: 1986 Monte Carlo SS Aerocoupe
Engine: L69 305 H.O.
Transmission: 200-4R
PB Blaster is some good shyt
Old Aug 6, 2014 | 08:09 PM
ex-x-fire's Avatar
This stuff works very well on fuel filter line connections, esp if the nut is frozen to the line. Follow the instructions as they say to blast it for 30 seconds or so.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
