383 Build cam suggestions
Subscribe
Aug 6, 2014 | 01:34 PM
Build so far....
350 4 bolt 2 pc .030 over block
Scat 9000 3.75 crankshaft 935050
6 inch rods
ARP bolts
Sealed Power 8-KH124CL30 Speed-Pro Hypereutectic Piston and Ring Kit
Piston Dia. 4.030''
Piston Top: Flat Top, 2-Valve Reliefs
Floating Pin
Moly Rings
Dura-Bond Coated cam bearings CHP8T
GM Damper 8 inch 6272222
GM Flywheel 3973456n
76cc GM Heads (462624 Casting), waiting for springs
Edelbrock Performer Intake
Holley 650 CFM carb...or no?
4 Speed Super T10
Center force clutch
Im looking for some camshaft suggestions. Would like a whole kit with push rods, rockers, springs, etc. Im hoping to get near 500hp, Mostly street will take it to the track once in a while. Please help guys thanks!
Reply 0
Aug 6, 2014 | 02:49 PM
Re: 383 Build cam suggestions
Not gonna happen with those crap heads and intake and small carb
I'd run a small cam like a voodoo 268 grind
Reply 0
Aug 6, 2014 | 02:58 PM
Quote: Not gonna happen with those crap heads and intake and small carb
Im willing to change parts i just need a little help
Reply 0
Aug 6, 2014 | 03:01 PM
Head casting that will flow closer to 270's cfm or more. 10.5:1 comp aluminum head 9.8-ish:1 iron head
Preferably a hyd roller in the low 230's at .050, mid upper 280's advertised duration. .550" lift or abit more.
Vic jr preferred or a ported performer rpm intake. 750 carb
Reply 0
Aug 11, 2014 | 12:27 PM
I agree with Orr as stated above. Not gonna get much performance with those heads. I think those heads are for a 305 sbc. Once you choose a better set of heads preferrably something in the 195 to 200 cc heads , then I would ask for cam suggestions. You wanna build the motor so you have a matched combo. But this all depends on what you want to use this motor for.
Reply 0
Subscribe
