Rocker to valve tip alignment off
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Only one on the whole engine that looks like this, reason I took the valve covers off is to readjust valves due to really bad idle and low rpm jerking/stuttering.
As you can see, its extremely far off, so far it is making the pushrod contact the head. All pushrod holes have been over sized 1/8" already.
These are 906 vortec heads.
Only thing I can think of is the stud is not installed straight? Any ideas?
This picture was taken while the engine was running.
Re: Rocker to valve tip alignment off
Either you're missing your guide plates or those heads need self-aligning rocker arms. That big hole where the pushrod is sticking through is NOT going to align the rockers like a set of guideplates or self-aligning rockers would.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Unless the rocker is self aligning, you need guide plates or the hole through the head is used as a guide plate to keep the rocker aligned. If the hole has been enlarged then there's nothing to keep the rocker from moving around across the valve tip.
The hole through the head needs to be fixed or you're going to have to find some way to use guide plates. Without screw in studs, that isn't going to be an easy fix.
Buy a set of shaft rockers. T&D etc. No need for guide plates and you can have the pushrod hole as big as you want.
Rockers are self aligning.
Comp 1617-16
This is the only rocker in the entire valve terrain that is like this, leading me to think elsewhere.
Comp 1617-16
Car: 1986 IROC Z28
Engine: 87 Small Block Roller Motor
Perhaps, what are the differences between the two? (Physically)
Car: 87 IROC L98
A self aligning rocker will have some sort of guides to keep the roller on the valve stem. Something on either side of the roller to keep it aligned. If there's nothing to keep the roller from sliding off the valve stem then they are not self aligning rockers.
Is the pushrod bent?
Pushrod is straight as an arrow.
Gotta give it to you guys, when you're right, you're right.
Will be contacting Comp...
RSlickster you rock man
This has been my life lately haha....
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
