Question about heads
Old Aug 14, 2014 | 08:31 PM
1984Z28ttop's Avatar
Car: 1984 Z28 L69
So, I just picked up a 350 out of a 78 Z28 and it has 77 305 small valve heads on it. I just got a set of free 350 heads with 1.94 intake valve, casting number 3998993 and was wondering if I should use the 350 heads instead. The engine is still out of the car on the stand getting new gaskets. From what I have been able to tell about the engine is that it has dished pistons, stock bore, weiand xcelarator intake manifold, 600 cfm edelbrock carb, and may or may not have a cam(have not dug that far in yet). I am planning on a set of headers in the future, but for now it will be a daily driver the 10 or so miles to and from work. Any suggestions?
Old Aug 15, 2014 | 02:55 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Question about heads
For comparison, what are the casting numbers on the 305 heads?
I think the 993 heads have 76cc chambers. If the block you're going to put them on has dished pistons you might have a combo that has lower than desired compression.
Old Aug 15, 2014 | 03:54 AM
Car: 1984 Z28 L69
354434.
Old Aug 15, 2014 | 11:27 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You dont have a single decent head in the bunch. The 434 heads are..... okay-ish... but they're massively outclassed by anything made in the last 20 years. Since you've got dished pistons you might as well use them but you're hobbling yourself.
Old Aug 15, 2014 | 03:58 PM
Car: 1984 Z28 L69
those are the heads that came on the engine when I bought it lol. I am kind of regretting getting rid of my old h.o. heads now.
Old Aug 15, 2014 | 09:22 PM
Car: 1992 Camaro RS
If your car had a factory 305, it was the same heads regardless of whether or not it was actually an "HO". The LG4 and L69 got the same heads, they aren't uncommon. I saw something indicating that the 434 heads are basically early 416 heads. Not sure how true that is, but the 416 heads are what were stock on LG4's and L69's.
Old Aug 17, 2014 | 12:54 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
The 350 heads are going to better than the 305 heads. A 350 is a better than a 305 any day. Enjoy.
Old Aug 17, 2014 | 09:50 PM
Car: 1992 Camaro RS
Nope......
Depends. There are some awful 350 heads, and some really good 305 heads. 350 heads usually have larger valves, but there were some 350s that got small valves too. There were some 350's that had heavily dished pistons, and there are some 305 heads that will bring their compression ratios up to something tolerable. You cant make blanket assumptions about "350" heads considering there's a zillion different variations from 1969 or whatever until 1998 with wildly varying performance levels.
Old Aug 18, 2014 | 12:16 AM
Engine: 355
yes I can. having access to test data on almost every factory 305 head available I know even old small valve 350 heads will out perform most 305 heads on a 4.00 bore. Yes 58cc 305 heads will boost compression but will run out of steam above 4500 RPM.
Old Aug 18, 2014 | 10:16 AM
Car: 1984 Z28 L69
So...put the 350 heads on? or 305?
Old Aug 18, 2014 | 11:00 AM
Car: 1992 Camaro RS
Perfect for a TPI car then, eh?
Old Aug 18, 2014 | 01:06 PM
Engine: 355
I would run the 350 heads. 58 cc 305 heads on a 350 tend to run hot.
Old Aug 18, 2014 | 06:35 PM
Car: 1992 Camaro RS
You dont think a 58cc "350 head" would do the exact same thing? Im not really sure there's such a cut and defined difference between "350" and "305" head...... I'd be more interested in tangibles like port volume, valve size, and chamber size, among others.
Old Aug 18, 2014 | 09:01 PM
1gary's Avatar
The 305 head swap was the hot ticket backwoods trick that backfired when it was found they didn't flow worth diddly even ported.
Old Aug 18, 2014 | 09:33 PM
Car: 1992 Camaro RS
These days Im starting to feel like any stock cylinder head is a waste of time.
Old Aug 18, 2014 | 09:43 PM
Engine: 355
3998993 307, 350, 76cc, 72-73,164/64cc ports, 73 had hard seats and 350 Crate motor, current, Hecho En Mexico, 159/64cc ports. 354434 1975-76 262,305 62cc, 1.72/1.30
305 bore is 3.736 and 350 is 4.000 inches. when 305 heads are used on a 350 there is a overlap in the cylinder causing poor combustion and hot spots around the ridge.
Vortec heads are a good choice. I made 462 HP with a flat top 350, Vortec heads on pump gas.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
