Changed distributor cap and rotor now Strange noise at load
Old Aug 17, 2014 | 01:08 AM
claus290373's Avatar
Car: Trans Am gta 5.7 1989
Engine: 350 tpi
Transmission: th700r4
Axle/Gears: BG 9 bolt
Hey
I just change my distributor cap and rotor.
Before i had no problems or noise but now
At engine load the car makes a strange sound.
Its Like a knocking sound.
Any good advice whats happend ?
I Will check the Firing order later when i am
Home but will the car run with a mixed up
Firing order ?
Thanks Claus
Old Aug 18, 2014 | 03:35 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Re: Changed distributor cap and rotor now Strange noise at load
Check that plug wires are at place(not lifted at dist. cap post)
Old Aug 18, 2014 | 06:31 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Yes, 8 cyl will run easily with 2 wires mixed up.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
