305 (L03) - scrap or sell?
Old Aug 20, 2014 | 11:15 AM
Flightoficarus's Avatar
Hey all, just a quick question - Long story short, I'm planning to pull the L03 out of my project (It has 3 bad cylinders). I'm planning to keep the accessories and the TBI - basically just getting rid of the longblock. Just curious if I can actually get any money at all for any of it, or am I better off just having scrappers pick it up? Thanks!
Old Aug 20, 2014 | 05:40 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 305 (L03) - scrap or sell?
nah, don't scrap it. sell it to someone who will need it for whatever reason. now if it were a Hyundai or a kia . yeah scrap it!
Old Aug 20, 2014 | 06:29 PM
TRY to sell it, of course.
Problem is, nobody wants that. So, give it a fair try, but don't expect miracles. As many low-perf garbage 305s as there are in the world THAT YOU CAN HEAR RUN RIGHT, it'll be an uphill battle convincing somebody that CAN'T hear it run (because it doesn't) that your FORNICATED one is worth as much as a penny.
Don't be too surprised if you get sick of your new lawn/driveway/garage ornament and decide to throw it in the trash.
Old Aug 20, 2014 | 06:43 PM
ex-x-fire's Avatar
Save the parts that you can use on a 350.
Old Aug 21, 2014 | 08:43 AM
Mayt13's Avatar
Car: 1989 Chevy Camaro IROC Z28
Axle/Gears: Stock
Honestly scrap it. You may want to do a kerosene leak down on the heads, if the valve guides/seals are good the heads could be worth a few bucks, then scrap the shot block. Or vice versa if the heads are junk and the blocks good. If it's all bad it's not worth the hassle.
Old Aug 21, 2014 | 09:07 AM
Joe Tag's Avatar
If you want to store a 305 block I have one that has been sitting in my garage for 3 years that I couldn't give away unless it was someone wanting it for scrap. I had ambitions of rebuilding it and went the 350 route instead. Not before I had the heads hot tanked resurfaced and valve job done. Sold the heads at a loss eventually.
Old Aug 21, 2014 | 11:21 AM
Car: 86 IROC
Engine: 5.0 TPI
the point that I was trying to make is this . you cant find a flat head ford because of this same thinking.everybody scrapped them. and now there are very few. now I know everybody don't have space for that. but hey, one day
Old Aug 21, 2014 | 11:41 AM
Joe Tag's Avatar
And I don't doubt there one day will be a need for it. Like I said, I still cling to the hope that someone will want my old block, really just the crank is good now unless it's bored. I just can't bear turning it into recycled iron for stuff being made today. I was just saying don't spend the money you plan on making selling this thing yet.
Old Aug 21, 2014 | 02:02 PM
Ex-x-fire - That's my plan!
Mayt13 - That's another thought I was curious about. A recent compression test on the motor suggests that the low cylinders have worn piston rings. But at the same time, back when I was driving the car, I had the classic worn valve seal symptom of smoke on startup as well (maybe it's both?). I have a slightly better feeling about the heads than the shortblock, but I guess I will find out soon enough.
Joe Tag - The offer is appreciated, but like yourself, I too plan to go the 350 route. Thanks anyway though!
Old Aug 21, 2014 | 02:31 PM
Joe Tag's Avatar
Sometimes you dribble, shoot and hope for the best.
Old Sep 6, 2014 | 07:10 PM
snake006's Avatar
I have a question I hope some one can anwser my LO3 in my trans am, I had my Holley carb put on it well had to buy a electric fuel pump bec my old motor used a mechanical one well my new Electric one keeps going out on me for some reason iv already changed out two in a month n it's bad again think it's a 10psi pump why is it going bad and how can I fix my probably plz help.
Old Sep 6, 2014 | 07:18 PM
Car: 86 IROC
Engine: 5.0 TPI
are you buying quality OR cheap pumps ? if youre going cheap .THAT may well be why you cant quit buying them.
Old Sep 6, 2014 | 07:43 PM
snake006's Avatar
All I know really I let my Mechanic but the part bec I work 12 hrs didn't have time to buy the stuff n work on it I think it's an acdelco
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
mcgarnicle
Aug 12, 2015 04:58 PM
