9th injector on 350 TPI
Old Aug 24, 2014 | 08:53 PM
botch1's Avatar
Car: 1990 Iroc Z Red Vert
Axle/Gears: Stock
Is there anyway to disconnect the 9th injector on a 87 350 TPI? What is it really for? I see that there is a small fuel line from the main fuel rail and a electrical plug. After car is started it has a odor of gas. I think that it is dumping too much fuel into the engine when it starts. I live in Wisconsin where it has been pretty warm. Any advise would be great. THANKS JIM
Old Aug 25, 2014 | 07:49 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: 9th injector on 350 TPI
The 9th injector is also called a cold start injector (CSI). There is a temp sensor in the front of the intake manifold. Below certain coolant temp, the CSI will fire. You can remove it, using any number of kits found on EBay or other sources.
You will need to (have the chip) reprogrammed for the main injectors to provide additional cold start fuel, or the engine will be temperamental when cold.
If you want to test this (for free!), simply remove the injector style wiring connector off the CSI. Start when cold, and see if that solves your problem.
Search on "cold start injector delete"... http://www.ebay.com/itm/TPI-Tuned-Port-Billet-Aluminum-Cold-Start-9th-Injector-Delete-Kit-/370791468159?pt=Motors_Car_Truck_Parts_Accessories&hash=item5654e4cc7f&vxp=mtr.
Old Aug 25, 2014 | 07:52 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
duplicate
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
