Can loose gas cap cause engine problem?
Old Aug 27, 2014 | 10:14 AM
Chuck's Avatar
88 Iroc-Z with 383, tpi.
Runs rough at low idle. Often kills.
But then runs fine for days
Someone suggested gas cap may be loose or defective.
Old Aug 27, 2014 | 10:18 AM
Damon's Avatar
Re: Can loose gas cap cause engine problem?
No. Later cars will throw a check engine light if the cap is loose, but 3rd gens have no such monitoring system.
Old Oct 22, 2014 | 04:50 PM
Chuck's Avatar
Thank you,Damon.
Chuck
Old Oct 22, 2014 | 05:06 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
