NEED HELP!!! Turns Over but No Start only with starting fluid
Old Aug 31, 2014 | 11:38 PM
EYEROCZ's Avatar
Hey everyone, this is my first thread.
I bought a 1989 IROC-Z 5.7L 350. Here is my situation. The car was not started for over 5 years. The engine turns over but will not start. When i spray staring fluid through throttle body it will start but die right away so i know i have a fuel issue.
Things I have done and tested.
- Replaced fuel
- Replaced fuel Pump and filter.
- Replaced Distributor Spark Module
- Replaced Battery
- Tested fuel pressure i have 47 psi at fuel rail.
- Tested spark i have spark at all cylinders
- Tested fuel injectors they are all over 14 ohms except for 2 which i have disconnected.
- Tested Injector Pulse with Noid light seems to flash extremely fast.
I really need help if you can offer any ideas they will be appreciated.
Old Sep 1, 2014 | 03:50 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: NEED HELP!!! Turns Over but No Start only with starting fluid
Sounds like gummed up injectors. Also, did you flush the old fuel out of all the lines?
Old Sep 1, 2014 | 11:07 AM
EYEROCZ's Avatar
Thanks for responding.
Yes i flushed the lines. What im doing as we speak is removing the fuel rail and injectors to blow everytthing out.
If the injectors are in fact gummed up. would that mean they are no good or are they fixable?
Old Sep 1, 2014 | 12:10 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
injectors may be gummed up, however, the car should still fire.
may run like ****, but it should still fire.
check TPS also. skip IAC steps...
https://www.thirdgen.org/tpimod2
if planning to upgrade injectors, choose these. dont bother refurbishing multec injectors
http://www.southbayfuelinjectors.com...tpi-injectors/
informative video
Old Sep 1, 2014 | 12:16 PM
EYEROCZ's Avatar
this video says it all
comparison bosch 24 multec lucas bosch3 bosch yellowtop bosch22 - YouTube
Ok i will check into that once Finish cleaning out the injectors.
Old Sep 12, 2014 | 12:15 AM
aramirez121's Avatar
Car: 1991 camaro rs v6
Engine: v6 3.1
Transmission: auto
if there is even a difference in the ohms in any one injector as it gets hot it will go up and throw it all off thus being said it sends a code to the ecm and tells it to shut down thats why it does that
Out-Cast
Mar 22, 2019 09:39 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
backtothe80s
Sep 5, 2015 12:39 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
